Question about Cisco Catalyst 6509 chassis
Looking for repair information on Cisco Catalyst 6500-series 1300W power supply (WS-CAC-1300, Sico PN: 341-0038-01 Rev. A0 - also labelled Sony Model APS-190 Sony Part no. 8-681-339-11). Are there common faults/failures of these units? Are circuit diagrams available? Thanks in advance, David Koch University of Newcastle Callaghan NSW 2308 AU Email: David.Koch@newcastle.edu.au
5 Suggested Answers
ward_knutson
  • 64 Answers
SOURCE: cisco 2960 power supply
The Cisco 2960 has a life time warranty. Contact the seller and they should be able to get the switch exchanged at no cost.
Posted on Jan 19, 2009
zutil
  • 16 Answers
SOURCE: catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Posted on Feb 09, 2009
SOURCE: I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: ''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Posted on Jun 02, 2009
Do I need to buy a software license for WS-C2960S-48FPS-L?
No. WS C2960S 48FPS uses the Universal image, but no license is required. The feature is bound to the hardware model type and cannot be changed. For convenience, a single software image is used for all Cisco Catalyst 2960-S Series Switches, regardless of whether they are a LAN Base or LAN Lite model.
Jan 20, 2015 | Cisco Catalyst 2960 Ethernet Switch ...
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Advise: Cisco Switch for small business?
I think Cisco Catalyst 2960 & 2960S Series Switches with LAN Lite, Catalyst 2960 Series Switches with LAN Base, and Catalyst 2960-S Series Switches with LAN Base is best choice. You can get more information in http://www.3anetwork.com/blog/cisco-switches-for-small-business/
Aug 04, 2014 | Computers & Internet
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
Apr 10, 2014 | Computers & Internet
Cisco WS-C2960-24-S switch port not working
Can you tell more details, there's various possibilities to cause the switch not work...
You can check your switch from these way:
1 check your cenect cord
2 check the power supply
3 check your network environment
For the Cisco switches, if you have any problems you can feel free to send email to our technicist:
support@3anetwork.com
Cisco Price Cisco Switch Price Cisco Router Price Buy Cisco Switches...
Dec 14, 2012 | Cisco Catalyst 2960 24 10/100 (8 PoE)...
I have a CISCO Catalyst 6500 Series Server Cooling Fan System - 6 Fan Tray. What voltage (AC or DC) does the tray run at and can I get individual fan replacements?
The individual fans are, most certainly, 12 VDC. Although I'm not sure if you are refering to individual fans, or the tray itself (I know most cisco products input voltage is ~120 VAC). If you are looking for a replacement fan, If would try the cisco website (if you have an extra arm and leg to spare). Or, if your as broke as the rest of us, you could try ebay.
Best Regards
ps. I ebay'ed cisco fan tray... I found complete fan trays... Most expensive 49.99 + shipping
Dec 28, 2010 | Cisco CAT 6500 HIGH SPEED FAN TRAY...
WS-X6724-SFP problem
serch on :Fiberstore.com .all kinds of sfp transceiver module in Fiberstore .Tt is a fiber optic products online store. you can access to fiber optic transceiver directly.
Aug 04, 2008 | Cisco Catalyst 6500 WS-X6724-SFP...
Cisco Catalyst 6509 chassis Logo
105 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
