Question about Tristar SB Steam Buggy Vacuum
How do you get the tristar apart - Tristar SB Steam Buggy Vacuum
Power head cord repair
Hi Kathy,
I don't know what model of Tristar vacuum you have but I have a tutorial in the link below that explain how to replace the cord.
http://www.diyvacuumrepair.com/cansiter-vacuums/how-to-replace-a-cord-on-a-tristar-vacuum-cleaner/
hope that helps.
Jan 15, 2016 | Tristar Vacuums
Where to find tristar blender model yd 208 motor
Do a web search and type in Tristar Blender Model yd 208 motor. If you can get the part number from your old one, that'll make the search even easier.
Aug 29, 2014 | Vacuums
Tristar vacuum has wiring pulled loose inside and I cannot figure out how to open the vacuum. It is a 1997 model. It appears that the rubber seal is holding the two halves together.
I have the same problem with my older '80s Tristar.
This may work for your model, give it a try.
On mine, there are 3 phillips head screws holding the two halves of the cleaner together, and the rubber bumper.
You have to remove the screws first. Your model may have more or less screws.
On mine, there are two screws near the front wheels, down deep. I had problems taking them out, but not to worry, once they are loose, they are no longer holding the other half, don't worry about taking them fully out.
Also, at the rear, there is a small black plastic clip that has a screw in it. You'll need to remove that too. Once all the screws are removed, use a medium sized flat head screwdriver to go behind the rubber seal -- you're looking to get the screwdriver to where you can see or feel the edge of the canister. Simply twist the screwdriver a bit and the canister should feel like it's coming apart. Mess around with that for a bit, and the parts should come apart easily.
May 02, 2011 | Tristar Vacuums
Where can I obtain a new tristar SB steam buggy nozzle from?
www.ApplianceZone.comLowest Prices On Appliance Parts Same Day Shipping Only $5. This place claime to have the parts needed.
I hope I helped.
Nov 06, 2010 | Tristar SB Steam Buggy Vacuum
I have a 30 year old TriStar (bullet style with thick bumper gasket around the middle) and the High/Low speed switch is burnt out. I am trying to find instructions for how to separate the shell to get to...
you remove the screw up front and the 2 scews buy the the rewheels from the bottom and then you pry the shell apart from the gasket it is tight but once you get it to loosen it come easy
Feb 25, 2010 | Vacuums
I was told that you do not produce the tristar vacuum..Is this true? And if so does that mean my warrenty on my vacuum is void?/
try this site to order tristar parts and accessories.
https://www.tristarvacuumscanada.com/
most warranties are from the brand, and not the place you bought it at. tristar still seems to be in business so your warrenty should be in tact.
Oct 26, 2009 | Vacuums
Power's off when the canister is removed or locked in upright
you have a clog someware. you should invest in a tristar cleaner. cheep vacs dont have near enough power to get much more than the stuff ontop. i am a tristar authorized distributer,you can call me just to talk 866-635-9254 or go to tristarclean.com call me3 when you are ready to buy a tristar. John
Oct 19, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Need new nozzle
Ebay ... but you can probably buy an entire new Steam Buddy for the same price.
Jan 21, 2009 | Tristar SB Steam Buggy Vacuum
Tristar***mg1
Looking for owners manual for a Tristar MG1.
Feb 17, 2008 | Vacuums
Tristar SB Steam Buggy Vacuum Logo
89 people viewed this question
Top Tristar Vacuums Experts
JoeVacs
Thatvacguy.com
Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
