Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 17.5 briggs and stratton engine model E1c707 type 0d28c1 or 0d28g1 code c90819za or c908192a where the wiring goes to from the carborator
  • 10865 Answers
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Posted on Aug 16, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Posted on Apr 30, 2010
  • 623 Answers
SOURCE: what type of oil do i use in my briggs stratton
You should be safe with a 10w-30 weight any major brand oil.
Posted on Jun 21, 2010
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
How old is the model 28m707
if you look at the engines code it will be model , type, code. The code is the yy/mm/dd of its production. so 990314 is 14th day of march 1999.
tho it may be yyddmm.
Aug 30, 2014 | Briggs & Stratton Garden
I just need to know where to find a wiring diagram for a briggs and stratton 9 hp engine, model 28a707 type 0122-02
There realy isn't a 'wiring diagram' for this engine. Are you looking for an 'illustrated parts list' perhaps? If so, go to ... http://www.partstree.com/parts/.... scroll down to Engines, click on Briggs and Stratton, then enter the model # and type # on the left. Leave out the word 'TYPE'... just put a - between the model, type and trim numbers. The parts are available anywhere. This site is just a good reference for mowers and engines diagrams..Hope that helps.........
Aug 14, 2011 | Garden
Want a repair manual for a 17 hp briggs & stratton engine
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Oct 01, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
185 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
