Question about Kitchen Ranges
Amana Range, Electric wont bake or broil
I have an Amana range, elective, smooth top. Model ART6510WW. Recently, it quit broil or baking.
Clues are as follows:
1. time just blinks. When try to bake or broil, it beeps and clock goes out for a couple seconds, then back to blinking. (I do hear a relay click when it goes out)
2. Resistance on bake element is 22 Ohm, Broil element is 19 Ohm.
3. Checked the latch, also cannot go into clean. Does not appear to be trying to clean (as I suggested in a help online).
4. 240VAC across 2 legs of source. Top burners seem to work Ok.
My suspicions point to the ERC-III unit, but it is costly. Want to verify before taking this plunge.
Please give suggestions.
  • Musselman Mar 23, 2008
    Couple more thoughts: cannot even set the time at all. I did replace the lower element about 2 months ago because it had burned out - but was now working Ok.
  • Musselman Mar 25, 2008
    clock won't set, but (I think) oven would operate anyway. Buzzer when you press keys sounds sick.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
The fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Posted on Mar 24, 2008
  • Ron Coons
    Ron Coons Mar 26, 2008
    yea unfortunaltly that does sound like an erc issue and ouch 200 bucks
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
The Bake ignitor in our Amana Gas Range (model #ACF3375AW) recently began to only work intermittently. Now it doesn't work at all. The Broil ignitor works fine. Any ideas? Thanks! Dana - Minneapolis
Hi Dana from Minneapolis...you need a new Bake ignitor, which is also called a glow coil. When it's working properly it glows a white hot colour and as it wears out it will glow an orange colour and needs to be replaced, this is why it began failing and then quit altogether. This is a part that requires an authorized gas technician to install for you. Good Luck.
Jan 26, 2010 | Amana Kitchen Ranges
Oven top element does not come on when baking
the top element is for broil only. if you have convection mode try that
Nov 25, 2008 | Hotpoint RB757 Electric Kitchen Range
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
405 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
