Question about Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor
Suddenly, I can see only a part of the display width. I can't control the width size in the screen setup (all the other functions are OK)
  • 979 Answers
Hello Harrison, the width size is being controlled by vertical stage, with the help of the on screen digital menu, the said vertical stage is working normally, but when the size or resolution of the screen is change the vertical stage fails to do this, because it does not have enough DC power to deflect the screen, you may need to replace the faulty filter capacitor on the power supply stage and on the vertical stage. this capacitors a high voltage rated, so be very cautious. after replacing the said capacitors test. thats it.
Posted on Apr 25, 2010
  • 4,924 Answers
See that it may be from the resolutions..if you give it a smaller one ..and it is a wide screen format ...it will hae black 2 inches wide band on each side... just right click on desktop properties and settings ..and restore a normal resolution on it ..
How do I change the font size
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
Screen width
Go to control panel, click display, click settings "top right" look for screen resolution, "lower left" put mouse over arrow and move one notch to the right, click apply, and a small window will pop up, asking to save setting, click ok, "repeat if needed" this will adjust screen size.
Apr 08, 2012 | Toshiba Computers & Internet
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
SAYS GOT PAPER JAM
With the message should say where is the paper jam. If you can not find this information you can try:
  1. Pull the paper tray, specified on the Display Screen, completely out of the printer.
  2. Remove any jammed paper from inside the tray slots. Make sure there are no pieces of paper jammed in the tray slots.
  3. Make sure to use paper within specifications and that the paper is loaded correctly in the tray. See the Related Items below for additional information.
    NOTE: When the paper edge guides are correctly adjusted, there may be a small space between the paper and the guides.
  4. Adjust the length and width tray guides:
    1. Length guides: Press the sides of the guide, and then slide the guide until the arrow on the guide point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guide will click into place.
    2. Width guides: Slide the width guides until the arrows on the guides point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guides click into place.
  5. Remove the top sheet of paper from the tray.
  6. Re-install the paper tray in the printer, and make sure it is completely closed.
  7. Make sure the pick truck and ****** roller set is installed and seated properly. Clean or replace both of these roller mechanisms, if necessary. See the Related Items below.
If none of this clean the JAM message you might want to power OFF/ON the device.
If that also does not clear the message you can go a bit deeper and reset the device. THIS WILL CLEAR ALL YOUR SETTINGS, might inclusive clean TCP/IP settings. So I advise you to print configuration report first then.
If you wish to do this here are the steps. NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAM to their factory default values. The print count and the Adobe firmware serial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM. See the Related Items below for additional information.
  1. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  2. Press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Aug 27, 2010 | Xerox Phaser 8560DN Laser Printer
Brother p-touch model 1880 label maker- how do you change the font size
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
I can't figure out how to make the font size larger
Try this solution to change the font size:
1. SIZE1 equals Standard Size.
2. SIZE2 equals Double Width.
3. SIZE3 equals Double Height.
4. SIZE4 equals Double Width & Double Height.
5. SIZE5 equals 4 x Width & Double Height.
6. AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Hope this helps.
Aug 04, 2010 | Brother P-Touch 1180 Label Printer
Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
The size range for custom size media is as follows:
    Minimum allowable page size:
    89 x 140 mm (3.5 x 5.5 in.)
    Maximum allowable page size:
    216 x 356 mm (8.5 x 14 in.)
  1. Open Tray 1 (MPT).
  2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
  3. When the front panel prompts you to confirm the type and size of paper:
    1. Scroll to Change by pressing the Down Arrow key and press the OK key.
    2. Scroll to the correct paper type and press the OK key to save your selection.
    3. For the paper size, scroll to Custom and press the OK key.
    4. Select Set Custom Width (W) by pressing the OK key.
    5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
    6. Scroll to Set Custom Height (H) and press the OK key.
    7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
  4. Select the custom size in the printer driver.
  5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
    • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
    • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
    Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
    • If you select Choose Specific Tray, select the Multi-Purpose Tray.
    • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
    • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
    • To create a new custom size:
      1. Click New.
      2. Enter the new name in the Name box.
      3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
      4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
      5. To exit, click Close.
    • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
    • If you create a custom size in certain applications, the driver lists the custom size automatically.
    MacOS 8 / MacOS 9 driver:
    • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor Logo
192 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
