Question about Sharp AR-M355N Copier
PLease i have a Sharp AR-M355u, i mistakenly reset the the machine to factory default. Now i can't enter the ip address. I checked simulation 22-10 it shows that the NIC is not installed. The lights on the NIC is blinking. I need help. Also can this equipment be used as a fax machine.
  • 52 Answers
Yes it can be used as a fax but please you need to contact the technician that install the copier
Posted on Aug 27, 2010
When I open my copy machine is a Sharp AR-M355U on the screen appears a message saying code H4-01 What should I do?
H4 error is heat roller under temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-outs on the fuser unit or the fuser lamp is blown.
Jun 21, 2011 | Sharp AR-M355U Copier
Jun 21, 2011 | Sharp AR-M350U Copier
We have a Sharp AR-M355U copy machine that we are going to be donating to a local charity. I was wondering if anyone knew if there was a hard drive on this machine, and if so, how would we go about...
Sim 62-1 will reformat the hard drive if there is one. On the key pad press POUND-STAR-CLEAR-STAR and enter SIM 62 copy button 1 copy button. If you cant get into sim 62 there is no hard drive. If you can get into sim 62-1 then follow the display press yes. and that will reformat your harddrive.
Aug 26, 2010 | Sharp AR-M355U Copier
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
Sep 12, 2009 | Sharp Office Equipment & Supplies
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Looking for a reset code for sharp ar-bc320
The default key operator access code on that machine is 00000
with this code you can enter network settings and change ip and subnetmask to your new requirements.
If this doesnt work you can get keyop password by entering simulation mode and get service report which has user code on it.
Apr 12, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-M355N Copier Logo
294 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
