My thintwin is not spinning, seems like motor is working but the central part is not rotating and its stuck
    Scholar:
  • 126 Answers
This sounds like a broken motor coupler between the motor and transmission. this is common in whirlpool washers.
Posted on Apr 26, 2010
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Jan 01, 2014 | Shuttle 9094 Emax Remote Control...
Error code f-51
The F51 code indicates that the control is not detecting proper motor rotation in the washer. This can be caused by overloading the washer, a fill problem or even a toy or item that is stuck underneath the washer that is preventing the motor from spinning properly. With the washer empty, see if the spin basket rotates freely. If you detect resistance, then you check between the basket and tub for an item that is stuck in this area.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
F07 occurs at end of first rinse cycle
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Whirlpool ThinTwin LTG6234DQ1
CHECK YOUR LID SWITCH IT HAS PROBABLY CAME LOOSE OR IS OUT. YOU CAN USE A OHM METER TO CHECK IT OR UOY CAN JUMP THE WIRES WITH A TEST LEAD
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool ThinTwin
have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
