Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Image is out of focus and pulsating green lines around some image
I've tried touch focus, it reads focus error, tried convergence manualy but it wont line up (green line on top left is curved). is this repairable and is it worth it? appreciate the help in advance...................
  • 80 Answers
Yes it is repairable will not be cheap.a tech will have to do the convergence inside the tv,the remote only does so much.i have had 3 in the past and when they get older they become dull,i would not by rear projection any more years going back that was the only choose you had for a big screen ,now lcd and plasma have come down in price i would be looking at that if i was you.
Posted on Apr 26, 2010
I have a double image on my screen. When I push
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 21, 2010 | Toshiba 65H81 65" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Convergence problem
Replace the Convergence amplifiers. Mine did the same. It was like watching a 3D movie without the glasses. It is not hard to do for someone who knows their way around a circuit board repair. Otherwise call a reputable service shop.
Jun 17, 2008 | Toshiba 50H81 50" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
Colors out of alignment; curved lines
this sounds like a convergence issue.. one thing you are going to want is a good test dvd.. avia - guide to home theater or video essentials are two very good ones. anything that will supply you with test patterns and let you pause on them will work.
you will need to get into the service menu, using your remote press DISPLAY, 5, VOL+, POWER in quick sequence. once the screen comes up you should have green letters and numbers at the top of the screen. at this point, keys 1 and 4 change the item, keys 2 and 5 change the category, keys 3 and 6 change the value, mute enters write mode, enter executes it.
you will want a test pattern displayed that has a center point, enter the pje section of the menu and go to tphp, if you don't see a crosshair, press 6. you are going to want the convergence grid and the test pattern displayed simultaneously, so press 9 until both are on screen. it will be a crosshatch pattern overlaying your test image. use the joystick button (left or right) to roughly line the crosshatch up with your test image.
now go to tpvp and use the joystick (up and down) to finish lining things up. once you are happy with the changes, hit mute then enter to save it to memory.
this next part is from a tweaks file in the public domain that i have for this model and use any time i am working on one of these.
How to Enter the Convergence Mode
Once you're in the service menu, you need to access the convergence mode. Press the 2 or 5 key until you see PJE in white blocky letters (you should be able to get there quickly by pressing 5 once or twice). Now press 9 on the remote. You will see a bracket appear in the middle of the screen. Press 6 and cycle through the different types of patterns until you get a white grid on a black background.
Controls
Once in the convergence mode (activated by pressing 9 in the PJE section), the buttons on the remote work differently. Keys 1 and 4 move the cursor around on the grid (convergence points) in a spiraling fashion. The joystick on the remote will adjust the position of the current color at that grid point. Key 3 cycles between red, green, and blue adjustments.
You may also depress the joystick, which will allow you to move the bracket freely around the grid. Press it again and you are back to being able to adjust the position of the current color at that grid point. Handy if you are just touching up an area and don't want to spiral through all the points.
How to Converge the CRTs
It's much easier to converge the set if you can see what you're converging. Green should be the color to converge to. The geometry (straightness of the grid) of the green CRT should be good enough - If you notice that some lines are definitely out of whack, you should straighten them.
We need to disable the red and blue CRTs. Press 2 until you get to the 2150P-2 category. Cycle through the items until you get to RGBS. Change the value to 2 (Green CRT Only).
Move back to the PJE category by pressing 5. You should be back at the grid with a green bracket - If you don't see one, press 3 until you do (the bracket may have been set on red or blue, which have been turned off). Navigate around the grid, correcting any obvious errors. Once you're satisfied, turn the red CRT back on (RGBS value of 6, Red and Green CRTs on), and return to the grid. Press 3 until the crosshair is red. Now, align the red to the green, getting as close as you can. By the way, not all grid points are selectable. Keep in mind that the edges of the screen will tend to be more out of focus, and harder to get "tight". Get it as close as you can. You also may notice that some points affect the position of other, nearby points. You'll get the feel for it after a short period of time. Now, do the same for blue, making sure to turn off red (RGBS value of 3, Blue and Green CRTs on). When you're all done, turn all the CRT's back on (RGBS value of 7, All CRTs on), and look to see the results. Touch up where it is needed (if needed at all).
I found the 100 IRE Crosshatch image really showed areas that still needed convergence. I would cycle within the PJE category (pressing 6) between the convergence grid (to fix errors) and the 100 IRE Crosshatch image (to view areas with convergence problems).
Save your convergence to memory by pressing MUTE followed by ENTER.
Remember, you need to do this for each mode you use - This doesn't mean for each input. It applies to 4:3 mode, 16:9 mode, and 1080i 16:9 mode (even though 1080i is a 16:9 mode, it requires its own convergence due to the higher scan-rate). Each mode is separate, and is saved separate, however, each one does tend to affect the other slightly.
Try not to use the Flash Focus. I know it's very easy to use, and they put it right there on the front of the set, so it basically begs to get pressed. But realize that pressing Flash Focus will rely on the sensors to converge your set - It will pretty much re-do all your hard work. It may get close, but it will never be as good as a service mode convergence.
Now that your convergence is done, you should re-register your new convergence to Flash Focus (FF). Ryan says below don't use Flash Focus, and I agree. However, if you do or someone else does, it shouldn't require nearly as much touching up if the new convergence is re-registered to Flash Focus. This is simple to do. While in the PJE category, press the Flash Focus button to initiate a re-registration process to the system. If the operation fails (I've never had this happen), press 0, followed by ENTER to restore the convergence settings you last saved. You'll need to investigate why it did not work. In the PJE category, change to item ERR and it should read a value other than 000 if your attempt at re-registering FF didn't work. If our attempt at re-registering did work, it should read a value of 000. Typically, reasons why re-registering FF won't work are due to overscan being reduced too much but there are other reasons too. Regardless, while you are investigating just don't press FF and you'll be fine.
I have read numerous forums regarding re-registering flash focus. Most say only re-register flash focus in Full. This is what I did. I only watch TV in Full mode anyway, so it worked well. I have read many people having troubles with other modes if they re-register flash focus in Wide Zoom mode so I can only say, read forums and ask questions if you do use your set in other modes before you re-register your flash focus in another mode besides Full.
hope this helps you,
trin
Nov 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Convergence problem
sounds like bad solder connections on convergance ic solder then if the problem still there replac ic
Oct 24, 2006 | Toshiba 57HX81 57" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
