Question about HP Pavilion A820n (PP165AA) PC Desktop
Literature for A820n indicates that component cables from a camcorder or VCR can be conncted to PC. There are no connections provided with this unit however. I wish to use the Intervideo software to capture some old 8mm video for editing later. Any suggestions as to a conncection scheme? Thanks Oliver
  • 503 Answers
Camcorder should have a usb connection on it someplace, This will be a mini usb port which will connect to your computers usb port. Cable will have one standard usb connection, other end of the cable will have mini usb end. VCR video will connect to a yellow connector if there is one on your computer otherwise you will have to check out the computer store for a video capture card and put it into your computer or have them do it. Hope this helps.
Posted on Apr 26, 2010
I need to know how to program a RCA universal remote RCU404N
Hello
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
Were does my chords go
The category of computer determines the wiring setup requirements. For example, setting up desktop computers is achievable differently than laptop computers. First, laptop computer has built-in ports only accepting cable connections from alternative devices mentioble as printers, faxes only mentionable examples. Peripheral device connections to laptop computer would usually be made possible with USB cables as the most versatile media link. Perform an observation on the ports area of the laptop computer to ascertain type of wiring usually indicated by design logo next to the port connection areas. Alternately, desktop computers have wiring complexities because of the several components that comprise an entire personal computer as also known PC. Desktop computers have a station unit where every device has to be connected to derive functionality. The unit also known as tower station or flat station depending on conditions that the remaining components lay along side or are piled on top of each other provides the name versions of PC units. Usually every components of desktop computer has to be connected to the unit taking peculiar attention to place the appropriate connection cables in the most suitable ports provided. For example, desktop computers require monitors as the computer display unit. The monitor is required to be connected to the tower unit or flat unit from where the processing instructions are acquirable. Prior to any connections, observe keenly the ports areas that have been provided demarcation logos determining which links placements are appropriate. Usually desktop PCs require monitor, keyboard, mouse connection acquire user experiences. The PC tower would have separate ports for each peripheral device requiring linkage. Observe keenly the ports provide located usually at rear view of the tower station prior to connection establishments. The computer user manual provides diagrammatic displays of the connectivity requirements of each component. However, computer connections area achievable by trial by error where the appropriate connection yet to be attained with practice.
Jan 25, 2011 | Computers & Internet
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Cinego connection cables
The question seems to indicate that you don't have the cables. The unit comes with three different cable for video input. One for Component (HD), one for S-Video (looks like the round plug for a mouse on a computer, but is wired differently), and one that has a single yellow plug that probably is compatible with your VCR. If you don't have the proper cables, get with your Radio Shack dealer to get the, since trying to use a cable which was not designed for the unit may cause damage.
Nov 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Camcorder connect to Insignia dvd/vhs copier unit
connect to front press av input button. set it on av 2. make sure your tv input is set to v2-component.
Dec 24, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
How to connect cords to camera, vcr and computer
Use the provided cable for your camcorder that includes either a rca (yellow, red, white) end or s-video, component, etc... then plug those into the input of your vcr.  you will need to select the correct setting on your vcr (possibly input 2) to view the camcorder.
Dec 21, 2007 | Sony Handycam DCR-TRV70 Mini DV Digital...
Transfering from camcorder to VHS tape
1. Using the A/V Cables provided, connect the proper end of the cable to the Camcorder where labeled A/V Jack 2. Connect the other end to the A/V inputs on the VCR. (Location of A/V jacks may vary by model) 3. You must activate the video mode on your VCR. Look for a button labeled: TV/VIDEO, INPUT, SOURCE, LINE IN, LINE 1, etc. (For more information, consult the User Manual for the VCR.) 4. Once you are able to view the camcorder playback on your television, press Record on the VCR and play on the Camcorder.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Watching tapes on TV
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
HP Pavilion A820n (PP165AA) PC Desktop Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
