Question about Kenmore 24442
Kenmore Elite, 9 years old, top loader. Agitates fine, but *sometimes* won't spin. Also failed to drain, but only one time, whereas the failure to spin is more common. I try to turn the timer knob to where it should spin, but it usually won't engage. Seems to have a better chance at spinning if I unplug it and replug it in the wall. When it does not spin, there are no noises at all (i.e. if it does spin, there is a click when it engages, when it doesn't, then no click).
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Apr 26, 2010
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Apr 17, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24442 Logo
88 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
