Question about Refrigerators
Refrigerator and freezer are not cold
The refrigerator and freezer are not cold. Our ice is melting and the food feels lukewarm to the touch.
Have someone to put some freon in it.
Posted on Apr 25, 2010
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
Freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Jun 06, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
My frost-free refrigerator is accumulating frost in the freezer and the and things are melting. the fridge below is too warm. the vents that circulate cold air to the fridge are clooged with ice.
You have a defrost problem. Unplug the refrigerator and put the food in something to keep it cold. If you feel comfortable, remove the cover on the rear inside the freezer and use a hair dryer to melt out all the ice. Do NOT try to chip out the ice or you will damage something. The problem could be the heater burned out, the terminator is faulty, or the defrost timer is bad. But once the ice is out, you can put it back together, the unit will work normally for a week or more before it ices up again. That will give you time to fix it, or call in a repairman.
Jan 04, 2010 | Kenmore Refrigerators
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
