Question about Ball Joint, Tie Rod, Pitman Arm Seperator Set
I own a 99 ford escort se was in the process of changing outer ty-rods and ball joints with the help of a haynes repair manual - i've completed installing the ty-rods but ran into a problem with the ball joints hanynes repair manual is rather vague in explanation upon removing the old ball joints the manual didn,t tell me that a swing arm would move up about four to five inches towards the engine its self and i don't know how to get it back down to posititon it on the new ball joint can you please help me thanks Brian from Buffalo
    Sergeant:
  • 242 Answers
I really need more info of your status.....However performing any front suspension work you need both sides of the front end off the ground and placed safely on sturdy jack stands...This will make all components of the front suspension more free to move easily..Although you may still need some type of prying device to set certain components in place it will save you time and labor to do it the easy way."..If you are in your backyard and don't have stands or proper tools and trying to do it one side at a time I understand and it is very annoying....Let me know and I will further assist you.....Hope this helps.......Brooks/Metalpoet.....
Posted on Jun 11, 2014
  • 382 Answers
Its a pain but you have to get a big pry bar in there to move it. I use a 6 foot piece of 12AWG Strut and pry it down.
Posted on Apr 26, 2010
Where are the grease fittings front chassis of 1997 ford escort
You will only have 4 of them. Outer tie rod ends and lower ball joints. If you still have OE parts on it, you won't have any. And some new parts don't have them. 2 on each side by the tires.
Aug 22, 2015 | Ford Cars & Trucks
What is the step by step process to replace cv joint transaxle on a 1998 ford Taurus SE
It's a job...but it may be best to get a professional to do this for the simple reason : once your remove the tie-rod ends, unless you have the nut marked down to the millimeter, your allignment will be off, which could at best wear your tyres down unnaturally, or at worse, result in the car being very unstable, especially around corners !
Sep 15, 2014 | 1998 Ford Taurus SE
Cant get the hub off of my 1997 ford escort
hub is part of the spindle need to remove outer tie rod and upper and lower ball joints to remove
Nov 06, 2011 | 1997 Ford Escort
95 ford escort I replaced lower ball joints and tie rod ends now my car is riding rough over the road feels like tire going to fall off. It never did this before until i change the tie rods and ball...
take it back to the place which did the work and ask them to figure out where they went wrong. if you did the work, take it to a shop and ask them to align it and tell you what else you should have replaced. i assume the struts and strut mounts were already replaced when you did this work?
Dec 12, 2010 | 1995 Ford Escort
I am currently changing front pads and think i should pack the wheel bearings but don't know how. its not covered in the haynes manual i got
Here I have the Step by Step :
Wheel and tire assembly Brake caliper and secure it out of the way with a piece of mechanic-s wire. Do not let the caliper hang on the hose. Brake rotor Halfshaft retaining nut and discard it Cotter pin and castellated nut from the tie rod end and separate the tie rod end from the steering knuckle using a suitable removal tool. Discard the cotter pin. Separate the tie rod end from the wheel knuckle ABS sensor bolt and the sensor, if equipped Strut mounting nuts and the studs which attach the strut assembly to the steering knuckle Strut from the steering knuckle Lower ball joint pinch bolt. Carefully pry down on the lower control arm to separate the ball joint stud from the steering knuckle. Wheel hub, knuckle and bearing assembly from the vehicle
Please Rate, Thank you
Aug 13, 2010 | 2000 Ford Escort
I need to change out the camber bolts. and i cant find the torque specs. can you help
CAMBER BOLT ON THE TIE ROD ENDS.YOU NEED A HAYNES REPAIR MANUAL TO GET THE TORQUE SPECS.YOU PROBABLY NEED WHEEL ALIGNMENT WHENEVER YOU REMOVE TIE ROD ENDS OR UPPER AND LOWER BALL JOINTS IT WILL ALTER WHEEL ALIGNMENT.
Jun 10, 2010 | 2006 Nissan Titan
Change the front wheel bearings on a 2005 taurus
Remove wheel
Remove axle nut
Remove outer tie rod nut
Leave outer tie rod nut on 3-4 threads
Hit spindle area where tie rod is mounted very hard with a large hammer (wear Saftey glasses)
The tie rod should loosen up and you remove it off spindle.
Remove lower ball joint nut
Leave nut on 3-4 threads
Hit spindle area where ball joint mounts (wear saftey glasses)
Carfully pry down the lower control arm too remove ball joint from arm.
Press in the axle towards the trans. out of the wheel bearing.
Place a piece of wood between the shock and inner fender to give yourself room to work.
Remove the three 15mm bolts that hold the wheel bearing on.
Hit wheel bearing out with hammer (wearing saftey glasses)
You may need to break a sweat on this part. Somtimes they are rusted in.
Be carfull not to damage the ABS sensor.
Reverse procedures to install
Sep 08, 2009 | 2005 Ford Taurus
Ball Joint, Tie Rod, Pitman Arm Seperator Set Logo
108 people viewed this question
Top Lisle Vehicle Parts & Accessories Experts
Rigger
Danny
Christian Krentz
Christian Krentz
Are you a Lisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
