Question about Frigidaire ATF6000ES Front Load Washer
Will not complete cycle and spell rubber? - Frigidaire ATF6000ES Front Load Washer
    Scholar:
  • 126 Answers
Look behind the back panel and see if the bet is hooked up. then see if you can turn the big pulley back there freely. let me know so i can help you more.
Posted on Apr 26, 2010
After 20 years of use, pieces of thin black rubber are deposited around the bowl after the wash cycle. Where is this material coming from?
are you sure that it is rubber
the black is mostly from the mud build up under the agitator from using washing powders that do not completely flush out on the spin cycle. Remove the agitator and /or bowl to clean out the gunk
after 20 years you will be amazed at how dirty the machine is where you can't see
Apr 09, 2015 | Washing Machines
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
Frigidaire Affinity keeps pausing mid cycle. Doesn't seem to make a difference which cycle is selected, any different settings and the washer still pauses. It will pause at least 5 times per wash, in...
there is an access panel on the back of the unit. 6 screws and on the bottom is a rubber hose that comes from the tub. inside that rubber hose is a filter cup. i have the same unit and mine did the same thing. took it out pulled clog out put it back together. works like a charm. hard to get at but you can do it. use a drill with a phillips head to make it quicker. Also have pliers and a pair of channel locks. Good luck and it aint the Timer TRUST ME
Nov 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
Top loader Speed Queen takes long time to complete one wash.
sounds like your belt is worn or the tension spring too tight on belt the vee part of the belt should not be rubber it should look like a material type coating to let it slip until it gets up to full speed (It,s Meant to slip) If it,s worn the rubber in the belt will grip too much.Hope this helps.Cheers.
Aug 06, 2009 | Washing Machines
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
The spell checker and spell check as you type does not work.
http://www.spellchecker.net/spellcheck/
I use this when I need to doublecheck my spelling
cut/paste your document into the spellchecker; and then paste the correction back into your document
Feb 02, 2009 | Computers & Internet
Water runs out of the rubber gasket inside the door
replace water inlet vale it has gotten debris in it and not allowing it to close
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
