Question about Toshiba Satellite A135-S4527 Notebook
Black screen / works on external moniter - Toshiba Satellite A135-S4527 Notebook
    Sniper:
  • 57 Answers
When you turn your laptop to different angles can you see extremely faint graphics? Try shining a bright light at it an turn it at a 60 degree angle to your eyes. If you can see any graphics then your inverter board is bad. It it located just below the screen in front of the keyboard. The inverter itself is very inexpensive (about $12). Having someone install it shouldn't take more than 45 minutes. Let me know if this helps you.
Posted on Apr 26, 2010
Accer asspire 5535 screen wont lite up but works with external moniter
so you had a new inverter put in, are you talking about the actual backlight? can you see anything on the screen at all? point a flashlight at the screen when it's turn on and try and look from different angles to see if you can see anything on the screen. you can also take the screen off and check the connection to the actual LCD.
Jan 27, 2012 | Acer Aspire 5535-5050 Notebook
When my computer is on the moniter is blank.
The monitor only has one cable and it is keyed to fit one way. They are always located under the top bezel. Should have roughly 20 pins and the wire will flow up into the display. If the screen is very very dim (look carefully) then your inverter board is most likely bad these run 40-120 dollars depending on model and are located along the bottom edge of the display itself. If the screen is completely black, try plugging an external monitor into your laptop (make sure you try toggling the display mode) [typically Fn + F7 or whichever says LCD or has a monitor icon.] If the external monitor works then your screen is most likely the problem and will need to be replaced. If the monitor does not work, the motherboard needs to be replaced. You will be hard pressed to find any schematics for motherboards but you could dis assembly the the laptop and easily check for descended capacitors, burns and the light though most of the time I doubt you will be able to see the damage.
Best of Luck
Jan 24, 2012 | Computers & Internet
Black screen
if you dont have any view on external monitor too  there so 2 reasons for.  1 is mainboard (graphic chip) 2 is LCD data cable that comes from Mainboard and goes to LCD.  need to go to Service
Apr 17, 2009 | Compaq Presario Notebook
Acer 9300 black screen at start, tried some things, didn't work.
The cables to the LCD and the Inverter board may not be hooked up correctly...
I have manual, I can email it to you. joediaz911@comcast.net
Apr 05, 2009 | Acer Aspire 9300 Notebook
My screen to my laptop dose not work what do i do
if its totaly blank , the first thing you should try is connecting it too an external moniter, that will rule out motherboard or graphics card problem if you get a display to an external moniter
Mar 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
Thanks for helping find the problem
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
44
Aug 22, 2008 | Computers & Internet
Fujitsu siemens 8830
check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Mar 01, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
