Mitsubishi Model # VA-60603, Serial # 128231. Just started having fuzzy showy reception on TV. Very slow response when changing channels.
  • Joel Witham Apr 26, 2010
    Okay, I rechecked all the connections from the cable TV. I do not have a box, just directly linked to the TV thru the VCR...everything is good and finger tight, the cables I'm using are all basically new. Still fuzzy and snowy, affects the sound also. This just developed last night it's been good up until then. I had the TV on a couple of times today, but got frustrated and turned it off. Thanks...Joel
    I found something else that is kind of confusing. When I turn on the VCR all the snow disappears and changing the channels are working correctly too? Of course the incoming cable is run thru into the VCR box then into the TV. I think I might replace that short piece of cable from the VCR to the TV? That's the only thing I can think of...otherwise I'll just watch TV thru the VCR till I get it worked out. I will also keep some of those other suggestions you all have made in mind too! Thanks.
  • 6,993 Answers
how long have you been using your TV? I am asking because I am suspecting your TV's bulb.
Usually, when bulb needs replacement, the TV screen is not usually bright/clear.
There is also a line transformer inside the TV could be responsible for this. The line transformer passes voltage to the TV tube and once it is bad, it can make a TV reception fuzzy.
So, my advice is that you take TV to a local repairer withing your vicinity to have the above mentioned parts be checked. Or if you have a knowledge about TV repairer, you can have them tested and replaced by yourself.
You can also hit the TV by the sides when you turn it on, it might make a difference.
Good luck.
Posted on Apr 26, 2010
  • 12,061 Answers
Ok, the FIRST thing we must check when we get "Snow" in our picture, is the ANTENNA, and Antenna connections. The TV reception, is dependent, on signal quality. You need to physically, inspect the Antenna, and the lead, and the Plug. This doesn't matter if it is Normal TV, DTV, or Satellite, even though, the Antenna's are different, they still need to be checked. IF the Antenna and setup is all OK, IF you are using a "Box", then this too, maybe the problem, you will need to establish, if each, unit as OK, or Not If those are OK, the Antenna, "Box" then, possibly what the problem is would be the Tuner, this may have developed a fault. You need to get this looked at professionally, to have your setup inspected, from the Antenna, to any "Box" to the actual TV. Once the problem is isolated, a remedy can be formulated.
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Mitsubishi hdtv projection model WS55311
I have an owners manual. I could send a copy for $10. Deborah deboraha-a@comcast.net
Jan 13, 2008 | Televison & Video
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Technical manual for Mitsubishi VS-60603
Yes there is! Go to http://www.servicemanuals.net and its available on a paper typre or instant download type for about $24.00. You can get parts nat http://www.partstore.com. Good Luck
Aug 29, 2006 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
