Question about Galaxy Radios DX-33HML 40-Channels Base CB Radio
Power problem the power wire came off on the inside of the radio and I can't figure where it goes to
  • Melanie Rogers May 11, 2010
    what wire? the one in the back of the 3 pin power plug and if so is it the red or black?
  • 4 Answers
I have one of these radios th dc power connector pins come loose move in out brak off inside rear plug There are two coiled chokes comming up from PCB one on left one on right they should match up with neg positive pins then theres 2 capictors acrsoss the pins
Need any more info :
empirecbradio@yahoo.com
Lateer Kc
Posted on May 12, 2010
Radio display not working
sure inside, radio.
check all fuses first.
make sure all 3 power wires are in fact at 12v.
if not , fix that first.
power ( goes to IGN1.
Dial (goes to dash park dimmer ckt)
memory (hot all the time)
Dec 26, 2013 | 2004 Jeep Grand Cherokee
I have a commax intercom (dp - 2hp model). There are two wires connected from the bell outside to the connectors 1 & 2 on the unit inside and the bell is working. There are another two wires connected to...
you just said where everything goes, so what's the question?
connector 5 goes to your gat actuator, 6 is power for the unit, obviously there will be 2 wires for each for a complete circuit.
Oct 04, 2013 | Radio Communications
Car Radios
If it is an aftermarket radio check the fuse, it might be blown if it is the manufactures radio then its probably dead and needs replaced, i would also retrace the wires and make sure non are touching or have been cut somehow, once it happened to me and a wire piece was sticking threw the black tape touching a metal piece inside the dash, this is why its best not to use black tape, and also if you running a system you might just need a new radio i fired a Sony one year could never figure out why it went out took it to a shop they said the system was to much and over heated the radio...crazy.
May 30, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
I have a 1988 chevrolet silerado truck and i'm trying to remove the factory delco radio but can't figure out where the wire - which is fixed - goes to from the radio
if it is a thick single wire it may go to your aerial otherwise there are speaker wires plus power supply wire....hope this helps.....cheers
Jul 04, 2010 | 1988 Chevrolet K1500
Radio and inside lights not working
Check your grounding, prob have used illumination line as ground, when lights switched on it goes to 12 volts and if connected to radio ground fuse will pop. Ground radio to chassis and isolate the wire you have used, replace fuse (probably blown) and should fix your problem.
May 25, 2010 | 1990 Nissan 300ZX
Stereo wiring codes
if you take a 9v battery, and touch it to the speaker wires, you can find out which wire goes to which speaker, OR you need only 3 wires ( memory, power, ground) to power the radio, then you should be able to figure out which are the speakers, or attach a speaker, and use fader and balance to figure out which channell that is on the radio
May 15, 2009 | Sony CDX-FW570 CD Player
Car radio wont work
If you Have Display Lights.Then the Memory wire is Hooked up .But the Power wire is not.That is the Red Wire Hanging.It was going to the fuse box before it fell off .Use a Volt Meter (DC).Or a12 volt test light
You Want a Fuse that only has Power (12 Volts) When the Key is Turned on.Use a little connector to connect the wire to that fuse...That will do it..Good Luck
Feb 20, 2009 | Car Audio & Video
I have a Pioneer GM-H100 amp and I can not figure out the whole 3 prong thing is there a special wiring for it i have seen mixed comments of this same problem on different website can you please help me...
I have a gm-h100 amp. The three prong plug is for a remote turn on. Mine has two wires one of which goes to the radio where it gets a power on sigonal (12 volts when the radio is on). the other wire goes to the an accesory fuse where it gets 12 volts when the key is turned on. the amp needs both of these before it will run
Jul 23, 2008 | Car Audio & Video
Tuning Radio
Sounds like it's wired up wrong. You need to refit the radio with the memory wire on a permanent live. Check that yellow and red wires aren't connected together, one is main power one is radio memory. Main power should go to the acc on you ignition and like I said the other goes to a permamnet live. The harness should look like this . . . . V
Apr 19, 2007 | Kenwood KDC-7011
Galaxy Radios DX-33HML 40-Channels Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
