Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Won't start John Deere 310D Rubber tire backhoe
After you jump start it you can run for 2 hours then it shuts down!
Batteries are good and alternater checks to be okay!
The electric parking brake will not operate when losing electrical power!
  • ryanutilitie Apr 26, 2010
    Once we jump start it it will run for about an hour then we loose power to electric park brake,Forward motion but have reverse and then 15 minutes later motor cuts off!I know it's electrical but where should I start looking?
  • danny herget
    danny herget May 11, 2010
    What is the machine model?Does it not start or does it not crank over?
    President:
  • 1,627 Answers
If you can test the alternator after it has run for 2 hours that would be helpful,if it is quiting after it gets hot then it likely need the stator replaced in the alternator.If this is not the case,then you need to either replace the park lock solenod valve or the instrument cluster is overheating a transistor and failing,this will cause the safety interlock circut to engage.Also the operator pressence switch may need to be relocated if the operator is less then 150lbs.Let me know how you make out,thanks.
Posted on Apr 26, 2010
  • danny herget
    danny herget May 21, 2010
    If the alternator remains working then the forward solenoid could be the problem,it may be heating up and not engaging.You need to get the codes from the machine and then go from there,but likely you need the forward solenoid valve replaced or the enable valve,the codes should take you to the problem.
  • danny herget
    danny herget Jun 24, 2010
    What exact model do you have?Have you checked the alternator output?What were your results?Do you know how to get the codes from the tractor?
Wont go forward or back
Posted on Jun 24, 2010
John Deere 310d 4+4 1996 turbo , runs great for a hour then starts surging and loosing power,then dies ,will start back but does same thing until cools completely off
check for vent in the tank
possible that it is blocked and the hot fuel is pressurizing the system causing an over fuel situation
if the return had a glass ball in it it is there for a reason so removing it may not have been a good idea
have a jd service center check it out
Jan 28, 2017 | Cars & Trucks
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
Keep getting a manifold overheating beep. even after light use. after 1/2 hour of starting machine. We clean the radiator before each use and air cleaner is good to go
Check the exhaust silencer for blockage, hold your hand at the end of the pipe and feel if there is a fair amount of pressure while it is running, if not, replace
Aug 18, 2015 | John Deere 310sj Backhoe
I have a 310g john deere backhoe with F9C4 & F9a3 that will not start motor just turns over how do I fix it
jump the starter to see if it is good if good check then silinoid starter jump that with jumper wires connected to battery if dosnt starter silinoide
Sep 14, 2014 | Garden
I need a routing diagram for serpentine belt on a John Deere 310SE backhoe?
You should be able to get that by going to the website for Gates rubber and belts.
Sep 12, 2014 | Cars & Trucks
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Jan 13, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
825 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
