Question about Sony VAIO VGC-LT33E 22? All in One Desktop PC
I am selling a sony vaio desktop and want to reset to factory settings. I have tried to perform a system recovery but it will not work. It came with Windows Vista and I upgraded to Windows 7. ??
  • rix1211 Apr 26, 2010
    Sorry for this question, but how do you delete the partition. I have vista and 7 on the system. When the computer starts up it asks which version to start. If I do nothing it defaults to 7. There are no recovery discs, the recovery discs are on the hard drive. I thought if I removed 7, I could recover the factory settings that were set in vista.
    not sure how to delete partition. computer came with vista and i upgraded to 7. when comp starts it asks which os i want to use. if i do nothing it defaults to 7. i thought i could remove 7 and then recover to factory settings. factory settings were set in vista.
    Novelist:
  • 128 Answers
Just go to the start button, all programs, accessories, and click on the command prompt. At the c; prompt in the window, type the following:
Format C:
answer all of the questions with "yes"
This will totally wipe the hard drive of all info.
If you have the original installation disks, you may want to give them to the new owners. It will make it easier to reload the operating system and drivers.,
so basically you should Format the drive, then install an operating system such as xp, or windows 7 .... it should install most of the correct drivers. If you have the original disks that came with the computer, use those.You may have to go to the manufactures website to find the exact drivers for the video and sound cards., but that should pretty much return it to factory settings. If you are really picky and have the bucks, you can contact SONY for the original disks.
PLEASE CLICK ON SOME THUMBS UP FOR THE ADVICE!!!
Posted on Apr 25, 2010
Testimonial: "Thank you very much. This is a solution to my problem. I learned a lot."
  • James
    James Apr 26, 2010
    1. Reboot the system and hold down the F8 key as it boots.
    2. A menu will appear. Choose 'start safemode with command prompt"
    3. when the C: command prompt appears type FDISK
    FDISK is a very powerful piece of software. What you will have to do is, find the partition that you do not want and delete it.
    You might want to download a program that can help you and is a little more friendly it is called Partition Magic.
    Use it to ID the Partitions and delete it.
    Good luck. You might want to read alot online about FDISK and partitions.
    James.
  • James
    James Apr 26, 2010
    Using the installation disks to reinstall will not work because You need to LOW LEVEL FDISK. When you are installing software, you are putting the information on a partition of the hard drive. The installation disks are assuming that you have already prepared your HD and chosen a partition to install it to.
    FDISK Or Partition Magic, uses LOW LEVEL commands to change the structure of your hard drive physically. Before you can do what you are talking about, you must Partition the hard drive the way that YOU want it to be. So you must first delete both partitions, then create one big partition, and make that partition active, then format the partition, then install the OS from the disks.
    Since you want to delete your current partitions right now anyway, using FDISK is not that dangerous for you. You want the info on the hard drive gone, so there is no danger of loosing something that you wanted to keep.
    Go into FDISK, Choose the different partitions one at a time and delete them. then, after they are deleted, create a partition, and make it active. Make the one partition the same size as the had drive capacity. You should get it eventually.
    Good luck.
    James.
    ALSO IF YOU COULD RATE EACH SEPERATE COMMENT THAT WE SHARE WITH 4 THUMBS, IT WOULD BE A GREAT HELP!!
The pc comes with a hidden partition on the hard drive which contains the factory default operating system. Make sure you backup your data first, then press F10 on boot and follow the instructions. If you don't get the recovery utility then you may have damaged the original Master Boot Record and F10 will not work. However, if you performed a simple upgrade you should still have access to this utility.
Posted on May 07, 2010
  • 30 Answers
CNTRL+F11 will not work since you have installed the cd and overwritten the partition your only option is to delete the partition and install the CD again
HOW TO reset model SVF15215CXB
Sony factory reset
You can recover your VAIO computer from the recovery area on the built-in
storage device. This recovery method is faster than using Recovery Media.
See
1. Press the ASSIST button while your VAIO computer is off.
The VAIO Care (Rescue Mode) screen appears.
2. Select Start troubleshooting (recovery).
Follow the on-screen instructions until the Choose an option screen appears.
3. Select Troubleshoot and VAIO recovery solutions.
Follow the on-screen instructions until the VAIO Care (Rescue Mode): VAIO
recovery solutions screen appears.
4. Select Start recovery wizard.
5. Follow the on-screen instructions
To perform custom recovery, select Tools and Start advanced recovery wizard.
This is a quote from the manual.
Th
Jul 09, 2014 | Sony Computers & Internet
How do i reboot my laptop
Restore to factory settings
Restoring your Sony VAIO computer to its original factory settings is a great way to remove old programs and files that are buried within your computer that you no longer need, or to get rid of a virus that you just can't seem to shake.
This process will allow you to start anew with your computer, and can potentially save you from simply throwing the computer away because you don't think it can handle the workload anymore and spending money on a new machine.
Unplug any cables connected to your Sony VAIO machine with the exception of the power cord and monitor.
Click "Start" in the lower left corner of your screen.
Click "Control Panel."
Click "Performance and Maintenance."
Scroll down to the bottom of the Performance and Maintenance screen and click "VAIO" recovery wizard. The VAIO Recovery Wizard dialogue box will appear.
Click "Next."
Select "Proceed with System Recovery" and click "Next."
Select "C Drive Recovery" and click "Next."
Click "Next" to confirm that you want to proceed with the C Drive Recovery.
Click "Finish" to restart your Sony VAIO machine and initiate the recovery procedure.
Upon restarting your computer, the Sony VAIO Recovery Wizard will prepare your hard drive for recovery and then restart your computer again.
The necessary files will be copied to your computer and your hard drive will be recovered.
Click "Finish" when a screen appears telling you that your recovery process is complete.
Your computer will restart.
Click "Next" when you arrive at the Windows setup screen.
Follow the on-screen instructions to setup your version of Windows.
When you have finished setting up Windows, click "Finish."
Upon restart, the Sony VAIO Recovery Wizard will install necessary files on your computer.
Your computer will restart automatically when these files are installed and your Sony VAIO will be restored to its original factory settings.
Hope this helps
Oct 14, 2012 | Sony VIAO Laptops (Laptop NOT Included)...
I want to reset my sony vaio
I'm assuming you want to restore your computer to the factory settings, so here's how to do that.
1. Restart your computer
2. Hold down the ALT key and press F10 repeatedly as it restarts.
3. This should initiate the factory restore option, which will reset your computer to an out-of-box state.
Hope this helps!
Aug 25, 2011 | Sony VAIO VGN-T1XP/L Notebook
I want to reformat on factory
Hi.
All the Sony VAIO Laptops are shipped with a Recovery Partition on the Hard Drive.
The Recovery partition will have the Pre-installed Operating System, Drivers and Sony Applications.
You may re-install the Operating System, Drivers or the Applications using this Recovery Partition.
You will find the detailed steps to reset the Computer to the Factory settings in the below link:
http://esupport.sony.com/
Open the above link and search with the article no: C1017279 in the search bar at the top of the page.
That should take you to the web page which has the detailed steps to perform the System Recovery.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
Aug 05, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/BJ
Sony vaio vgn-ux380n back to factory default
I'm glad to provide the steps to set the VAIO to factory default. Please perform a system recovery to go to factory default. Please click hear to view the steps to perform a system recovery if you have the recovery discs in hand.
Click hear to view the steps to perform a system recovery without the system recovery discs.
Thanks for understanding. Please let me know if you require any clarifications.
Jun 26, 2011 | Sony Computers & Internet
How to do full system recovery for my sony vaio PCG-4JBP? thk u
Not sure what you mean when you say "full system recovery" but the operating system will have system restore points that you can access from the control panels system protection option. If you want to perform a factory default reset, start up the laptop and then look out for options that can be accessed by pressing one of the number function (Fn) keys. I believe the Vaio range comes with an option to restore the laptop back to it's shipped factory defaults, the interface is reliable and did a great job when I restored a Vaio VGN-NW20EF, came out like new!
Apr 12, 2011 | Sony VAIO Notebook
Where is reset button of sony vaio vgn-b100b?
Unfortunately, there is no reset button in this model. If you want to restore the factory settings in the computer, please perform a system recovery using the recovery partition or the recovery discs.
Thanks!!!!
Dec 24, 2010 | Sony VAIO VGN-B100B Notebook
Want to reset Sony VGN-NR160E/s Vaio NB to factory
try the recovery disk or the recovery option of the sony vaio
May 15, 2010 | Computers & Internet
Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
iTechGuru
www.itechguru.in
Mar 29, 2010 | Sony Computers & Internet
Sony VAIO VGC-LT33E 22? All in One Desktop PC Logo
268 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
