Question about Dell Computers & Internet
I am replacing my dc power jack in my dell mini inspiron 10. how to open computer to replace it.
  • 3,940 Answers
My dell inspiron mini notebook wont turn on
Is it getting power? Check the plug at the computer for DC volts? Has the AC/DC jack in the laptop been damaged due to pulling on the cord? Try another cord/charger with the EXACT same power specs.
Mar 08, 2013 | Dell Inspiron Mini 10 Notebook
Dell inspiron "plugged in not charging"
There are some troubleshooting steps for this sort of problem:
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure your dell inspiron 1545 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Jan 14, 2013 | Dell Inspiron 15 Laptop
How do i boot my dell inspiron mini
The problem is most likely in the DC jack in the laptop, it works it self loose over time until there is no power or intermittent power. The only solution is to dismantle the laptop down to the motherboard level to replace the plug or resolder back in place.
May 18, 2012 | Dell Inspiron Mini 10 Notebook
Bad power cord or bad connection on laptop?
Probably the DC Power Jack which is where the power cord plugs into the computer. Take a ink pen and stick the tip in where the power cord goes to see if it wiggles. If so, that's your problem.
Mar 31, 2012 | Dell Inspiron Mini 1012 Netbook
Okay. I have a Dell inspiron mini 10. I bought about a year and a half ago. I messed up when i spilled kool-aid on my computer, but i immediately turned it off, wiped off the stuff, opened up the innards...
Hi there!
The motherboard of your Dell Inspiron Mini 10 needs to be replace. If you don't have the Complete Care warranty, then Dell will not replace it for free. I suggest you contact Dell Technical Support and asked them how much it will cost to replace it. Also, check how much a new computer will cost and compare it to the price of replacing the motherboard. You can have an idea if its cheaper to replace the motherboard or to buy a new one.
Hope this helps
May 11, 2011 | Dell Inspiron Mini 10 Notebook
Replaced DC power jack on Dell Inspiron B120. When I turn on the computer the 1st green light stays on steady the 2nd and 3rd blink occasionally but the screen is black. Any suggestions will be...
There could be many reasons for your problem from shorting something out while the motherboard was exposed to over heating the area at the power jack. My first and simplest suggestion would be to remove, and re-seat the memory modules. Are you sure you have good solder contacts on the jack you replaced?
Apr 30, 2011 | Amstron Dell Inspiron B120 Laptop AC Power...
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
Dell 910 mini will not recognise any battery and will not recharge
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Computers & Internet Logo
185 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
