I have a 47 inch phillips hdtv and a hp elite cpu the hp eliute has a blue ray player there hooked up though a hdmi cord the tv starts up windows and shows safemode but when it goes to the password screen the hdtv goes black for about 15 seconds and then ti goes blue and says no signal ive tried everthing plz help me
  • 508 Answers
tv starts up windows and shows safe-mode. That right there is your problem, windows defaults the monitor down to regular 640 mode. I will cut out the hdmi since that is not a monitor. Safe-mode is used to trouble shoot your computer and it loads just barely the drivers you need to see and work with the computer. You will have to get the computer to boot up normally then proceed from there, also you will have to set up your video card to output hdmi.
Posted on Apr 27, 2010
How do I hook up this DVD player to my 60 inch Westinghouse model #VR-6090Z ?
If your DVD player has HDMI, use it. If not, you'll need to buy a cord for it. Look on the back of the TV and the back of the DVD player. There should be colored connectors on each one. On the TV, it will be an input. On the DVD player, it'll be an output. There will be either 3 connectors or 5 connectors on the TV and DVD player. You'll need a cord with either 3 connectors on each end (red, white, yellow), or one with 5 (red, white, blue, green, red). Once you figure out which cord you'll need, buy it from any store that sells TVs and hook it up. The link below has pictures
Video Connectors Tutorial Hardware Secrets
Feb 02, 2015 | Westinghouse Televison & Video
I have a Emerson Tv that doesn't have a HDMI input is there a converter I can buy to hook my bp145 LG Blue-ray up
There is an adapter that goes from HDMI to DVI, There is even a cord that is HDMI on one end and DVI on the other.
A lot of TVs have the VGA PC connection on the back, not sure if your model has it, but you need DVI specifically and its not as common on TVs.
Jan 23, 2015 | LG BP320 FuHD 1080p BRay Disc Player,...
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
How do you hook a sony blu-ray dvd player to a Toshiba 51H83 51-inch HDTV
Step 1:
Hi there you need an adaptor follow this link
Step 2:
http://www.cablechick.com.au/cables/premium-usb-to-hdmi-dvi-vga-1080p-display-adapter-pc-or-mac.html
Dec 29, 2012 | Sony BDP-S590 3D Blu-ray Disc Player with...
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
Pioneer elite 2006 50" tv How can I change from
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
Apr 05, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I want to know what type of cable wire do you need to hook up for HDTV and where you hook it up at on the TV
HD can come from two types of cables. A RF cable, normally it is a RG 6 or maybe a RG 59 coax cable. A HDMI cable is the other method of obtaining HD on your HDTV. A HDMI cable has a rectangular shape with small pins, its about 1/2 inch wide by 1/8 inch in height. The RF connector is about 1/4 in circular. A HD signal can come from a cable box or it can come from a DVD or Blue Ray player. Google these type of cables and look on your TV for the connectors.
Jun 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Is a blu-ray player compatible with a rear projection tv phillip?
You need to use an HDMI connection from blu-ray player to the television. If your tv does not have an HDMI input the tv is probably to old and will not accept 1080P. If it does have an HDMI connection it should display a minimum of 1080i.
Jan 29, 2009 | Zenith E44W46LCD 44" Rear Projection...
Phillips dvd player
i need to figure out how to burn a dvd with my phillips hdmi recorder.
Sep 13, 2008 | Televison & Video
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
