Question about Chapin 2 Gallon Spectracide Sprayer
Pump does not wark
Pump does not work 2gallon spectraside sprayer
  • 3 Answers
Pour about one cup of water with a dash ( tablespoon) of liquid dish washing solution onto the top of the container trying to get as much of the mixture into the handle void of the sprayer chamber. You are trying to lubricate and clean the pump. If this doesn't help the pump to build up pressure then you can look for two clips around the top where the handle and bump body are connected. If you can seperate these two parts you can see the O-ring at the bottom of the pump handle and confirm it is clean and smooth. Rub some crisco yes, crisco on it to get it lubricated and put back the plunger into the body and make sure the clips snap back together. Now turn the completed piece upside down and see the little round rubber piece? Carefully rotate it and confirm that it fits snugly onto the bottom of the assembly. Do not pull it out!! If it is old it may break. So far are you still with me?? Good! Put it back together ( putting a little crisco on the gasket between the tank and the pump assembly won't hurt here either) try to pump up the pressure. We done yet?? No? builds pressure but won't spray? Well on to the wand. Feel lucky?? Take off the wand AFTER the spray valve the thing you push to get the spray out. Try to see if the water comes out easily under the pressure you pumped up. Careful, at the very least you have the soapy water plus God know what left over in the tank as you do this. We just want to see if there is any blockage from the tank to the valve. Unless you got foreign matter into the tank of the sprayer this should not have a blockage here. You can take the valve apart but it can be a problem sometimes PLUS Remove the pressure before you do it. Work your way down to the tip to see where the blockage is. Most often it is at the tip just behind the removable cap. The cap itself can become blocked. I carefully blow out any crud. I use air from my lungs blowing from my mouth but do not recommend this method especially if posions are being used. More often it is the holes in the wand that allow the pressured spray to come out. A paper clip works great here. Bend open and clean out the holes. DO NOT use the paper clip on the cap!! you will enlarge the hole and ruin the spray pattern. If after all this you still can't get it to work properly sometimes using some of those lime away products can clean out the hardened crud.
Posted on Apr 27, 2010
Volvo c70 windshield sprayer not working
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
Sep 04, 2014 | 2009 Volvo C70
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
Washer fluid not spraying out onto windows
when you push the button to spray the window "do you hear the sprayer pump motor"?
If no, your sprayer pump motor could have failed or come diconnected. now if you do hear the sprayer pump kick in then> check your lines "the small rubber hoses that lead to the actual sprayer nossels. make sure the small hoses are not damaged and leaking and not pinched or restricked.. in rare cases the sprayer pump could have failed and still make a sound like its working but not pump out any fluid.. also in some cases BUT RARE you could have a line or filter screen plugged inside the washer resivor.. Good Luck!
Sep 13, 2011 | 2003 Chrysler Voyager
How do i release the pressure in tank?
If you turn the top (fill) handle it should release the pressure. Sometimes you have to also pull the trigger at the same time you turn the handle.
Jul 15, 2011 | Stanley Lawn and Garden Deluxe Steel...
Back windshield wiper is working but no water coming out.front side are working fine.what causes it,not to have water at the back?
Your washer system could be low on water, the pump that pumps water to the rear sprayer could be bad or the connector could be loose, the hose to the rear sprayer could be busted or the rear head could be clogged.
There can be many things affecting your sprayer... goodluck!
Mar 27, 2011 | 2000 Toyota RAV4
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Chapin 2 Gallon Spectracide Sprayer Logo
618 people viewed this question
Top Chapin Garden Experts
Nick Olsen
ray gallant
Are you a Chapin Garden Expert? Answer questions, earn points and help others
