Question about Poulan Pro Chain Saw 46cc 20"
Have a poulan chainsaw that won't idle/stay running and bogs down when you press the trigger control. Do you need a certain wrench to adjust carb??
  • 38 Answers
No carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
Posted on Apr 30, 2010
My Poulan chainsaw runs at maximum idle when I release the chain lock then stalls when the trigger is pressed....What adjustment screw do I use
The carb has two screws a L screw and a H screw, the L screw will be the closest to the cylinder and will richen the mixture at idle and will help acceleration, the H screw will control the maximum revs, you can try un screwing the L screw 1/4 turn out ( anti clockwise ) if this does not help there could well be some other issue creating fuel starvation, possibly a blocked filter in the tank or in the carb itself.
Mar 17, 2018 | Poulan Garden
Set H&L jets oh a poulan p3314
I believe there is also a idle adjust.
adj. both L and H 1 1/2 turns approx from closed (bottom) for initial start up. check video links below, press the helpful button
http://www.poulan.com/ddoc/POUO/POUO2004_USen/POUO2004_USen__530165293-01.pdf
How To Easily Fix Chainsaw That Bogs Down By Adjusting The Carburetor
HOW TO ADJUST POULAN CHAINSAW CARBURETOR .
Jan 22, 2016 | Poulan Tools & Hardware - Others
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
I have a poulan 335 weedeater it is six months old it starts with choke but when you press the trigger it bogs down and stalls you can keep it running if you keep the trigger pressed but if you let off it...
If its only six months old i would think it is a carb adjustment issue ( running too lean ) you need to richen up the mixture by un screwing the mixture screws, start with 1/8 turn on each
Jun 30, 2012 | Poulan Garden
Won't idle, cranks and runs fine as long as trigger is depressed
Could be just a carb adjustment required, the L screw on the carb will richen up the mixture, if increaseing the the idle screw does not help, try extra 1/4 turn out on the L screw, make sure the air filter is clean before makeing any adjustments.
Feb 12, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Chain Saw 46cc 20" Logo
1,261 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
