Question about Maytag MED5700TQ Electric Dryer
Maytag dryer (Model# MED5700TQ0) will not start. Light inside works, but the tumbler won't turn. the door is completely shut.
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
Open the door and grab one of the baffles. Check to see if there is major resistance when you try to rotate the drum. No major resistance = a broken drive belt
A broken drive belt will also trip the belt safety switch by the motor and will not allow the motor to start.
The drive belt is item 26 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161471
Please check the door switch for a click when you just open or close the door. Within about 1 inch of closed usually you will hear an audible click. You said the light works so I doubt the door switch is the problem... (it still can be the problem though) 1/2 of the switch is for light control the other half for drying control.
The other suspects can be
1. The start switch
2. Timer control
3. Motor control switch
ONE more thing to check is go to the main circuit breaker panel and physically push the dryer CB to OFF then back on. After doing this try to start the dryer. Sometimes ONE of the 2 CB's trips for unknown reasons.
Finally if the dryer vent system was restricted and the the dryer got very hot (309 Deg) the thermal fuse on the side of the internal rear duct housing will also shut off the dryer and it will not start.
Item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161471&diagram_id=907130#d907130
http://www.appliancepartspros.com/part_details.aspx?part_id=3094244
Before you return the dryer to service... vacuum everything including all ducting internal and external to the dryer. Do not forget the thru the wall vent flapper where it exits the outside wall.
Thanks for using FixYa
Kelly
Posted on Apr 25, 2010
  • Kelly
    Kelly Mar 01, 2011
    I have only been doing this for 40 years. I can help you but rating the post with no communication does nothing to get your dryer fixed. My only goal here is to help you get your dryer fixed. It is NOT about money or me getting a big head. ""What have you done to troubleshoot so far?"" Lets open a working dialogue and see if we can not get your dryer going again.
    Kelly
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone ba
Yes it could have gone bad. Also you might be missing one of the 120 volt legs that the dryer needs to run. Try turning the Dryer circuit breaker all the way off then back on and see if it will work. It also could be that the belt that goes around the drum might have broken or come off the motor. If you can, open the top of the dryer and look for the belt to see if it is OK. Best of luck.
May 08, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Tumbler won star
What is the complete model number of your unit?
Dec 03, 2012 | Maytag MDE2400A Electric Dryer
The tumbler won't turn.- Model DG7500
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 20, 2011 | Maytag Dryers
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
Tumbler does not want to turn. Belt is ok, I turned it by hand from the inside and using the belts from underneath. You hear that it wants to turn.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Nov 26, 2010 | Maytag MDG7600AW Gas Dryer
Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Jul 24, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone bad?
i would start with the door latch if its broken the dryer will think its door is open and wont turn on
Apr 21, 2010 | Maytag MED5700TQ Electric Dryer
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Open Questions:
See all Maytag MED5700TQ Electric Dryer Questions
Maytag MED5700TQ Electric Dryer Logo
503 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
