Question about Epson NX415 All-In-One Printer
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
  • 4 Answers
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Posted on Apr 25, 2010
Epson printer xp -800 not detecticing ink catrages
Are your carts all Epson or are they off-brand?
If one particular cart isn't being detected, it may be defective.
If you get an error message about the carts, some chips used to work fine, but Epson "upgrades" to the driver change the compatibility, and getting new chips can help.
Feb 27, 2015 | Epson Stylus Office Equipment & Supplies
I have changed the black cartrage but get Error 88/69
1) Remove all ink cartridges, unplug, plug back in,
put all ink cartridges back in--should now work
2) if not, download drivers from epson.con, and install &
then do 1 above again
Jan 23, 2015 | Epson Stylus NX400 InkJet Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
I installed new ink cartrages in my Epson C86
this is idicative of a waste pad counter overflow, the ssc printer utility can clear the inbuilt counter but if your using your printer a lot it would be a good idea to replace or clean the waste pad, its inside the printer and will bee messy but if your doing lots of prints it will be less messy than if it overflows
I forgot how to change my epson cx6600. Please
There is a general how to on the printer manual.
Please visit this link:
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
The steps on how to change the ink cartridge is on page 12.
Aug 22, 2009 | Office Equipment & Supplies
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Won't print after changing ink cartrages
After you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks,your printer will require service.
Contact an Epson technical support representative at (562) 276-4382 for further assistance.
Nov 24, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Epson NX415 All-In-One Printer Logo
218 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
