Question about Sewing Machines
BOBBIN WINDER WILL NOT MOVE,I CHANGED THE SMALL BELT IT IS STILL FROZEN.
  • 980 Answers
If thye winder will not move at all then the chances are it may be seized through lack of oil, you can take an electric drill and put it over the winder pin but put some WD40 on the winder pin first then turn the drill on slowly and it should free off, watch for splashes of oil.
Posted on Apr 26, 2010
Brother 1100, was sewing , now it is froze, cant turn the wheel far either way, cleaned, wants to go but is stuck, I cant see any thread in bobbin plate but I think that is where issue is advise
You could check the bobbin winder shaft. If this is engaged the machine appears to have frozen while turned on. Move the bobbin winder shaft left, then right while checking the foot controller and you will soon know if this is the problem.
Nov 08, 2016 | Brother Sewing Machines
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
It was working now it seems to be frozen the needle part wont move
Mar 06, 2016 | Kenmore Sewing Machines
Why doesn't belt move to sew?
retighten the hand wheel .
Mar 06, 2016 | Sewing Machines
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
Machine frozen
Switch the bobbin winder on and then off again, crisply, or turn the knob in the middle of the handwheel to tighten the clutch. If still no response, your machine may have a broken belt or be seized from lack of proper lubrication.
Dec 29, 2013 | Singer Sewing Machines
Bobbin winder wont wind
Is the winder wheel touching the drive belt when pushed forward. if not loosen the 2 screws that hold winder and move it so the wheel just touches the belt.
Jun 09, 2013 | Juki DDL-8700
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
