Question about Weber Genesis Silver A Grill
The grill doesn't heat up past 450 degrees. Earlier it didn't heat up past 300 - I took it apart and tapped on the lines to see if they were blocked. Any other suggestions?
  • 140 Answers
Close you air flow on your burners!
Posted on Apr 28, 2010
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
Heating
It sounds like the regulator is shutting down and preventing the grill from getting all of the propane it needs. to remedy your problem disconnect the tank and then reconnect it. Usually that is all it takes to get the regulator to work properly. If the problem continues just get a new hose with regulator attached.
Jul 07, 2009 | Weber Spirit? E-310 Propane Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
Grill won't heat pass 300 degrees, burner and lines clear of obstruction, could the problem be in the regulator?
yes, these regulators are known to get stuck. Try kinking the hose until you her a click in the regulator, this will open the valve. It may close again shortly after you release the pressure but worth a try.
Apr 04, 2009 | Thermos Stainless Steel Gas Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver A Grill Logo
197 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
