Question about Kenmore 62822 Electric Dryer
Squeeking A very load squeeking noise while dryer is on. Kenmore model 110.96573230
    President:
  • Kenmore Master
  • 2,651 Answers
Most common problem is a bad idler pulley and/or roller assy, you can order a repair kit for your dryer probly under $40, includes new rollers, belt and idler pully part number 4392065
Posted on Mar 24, 2008
SOURCE:
My kenmore electronic dryer makes a squeeking noise when it spins
Open it up and and put some grease on the fan. The other cause is - untied bolts.
Jan 21, 2013 | managemylife.com
Dryer just started making squeeking noise and then seems to overheat and won't run again until it cools down.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfgshs
Sep 29, 2010 | Kenmore 63942 Dryer
Why is my Kenmore dryer squeeking when it runs??? Very very annoyign and have no clue what it is..thanx you
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 26, 2010 | Kenmore 63942 Dryer
Kenmore washing machine makes a squeeking noise
Sounds like you have something between the tubs. If it only does this in the spin cycle, I would look for something between the tubs
Please rate solution if helpful
Aug 24, 2009 | Kenmore Washing Machines
Squeeking noise when dryer barrel or blower wheel turns
Sounds like the fan blade hub has become worn. Remove the front to gain access and secure a hose clamp around the hub. It may be necessary to trim away some of the plastic vanes to allow it to fit snugly.
Apr 26, 2009 | Dryers
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore 62822 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
