Question about Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Posted on Apr 26, 2010
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
Collet lock will not lock collet in place to remove stuck bit
The push button used to hold the collet in place whilst the spanner is used to loosen it engages in a slot in the shaft. Rotate the shaft slowly while pressing firmly on the button. If the slot is not located after a full turn of the shaft, the button must have seized. If so, you will need to dis-assemble the router to free it. There are articles on the net on how to do this for most routers.
Apr 07, 2016 | Ryobi R160 Routers
How do i change the assesories that come with dremil how do i use the hand held dremil??
If you have the standard dremel tool ther is a small bar sticking out at the collet end of tool. This is a locking rod to hold motor shaft in place so you can loosen coollet nut. Put pressure on thebar and slowly rotate the shaft until the bar drops in place. There should be a small open end wrench that comes with your tool to loosen nut. If not use asmall wrench to loosen nut.Turn it counter clock wise to loosen. It is not needed to take the nut all the way off. You may have to move tool slighyly to get it to come out.
The tool that you use is determined by what job you are trying to do.Most come with abrasive cut off wheels small grinders,sanders,and polishers.To secure new tool in collet just insert tool shaft in collet and tighten down. When it gets snug then Depress locking bar to finish tightening. Hope this helps you some. Thank you.
May 29, 2011 | General Hand Tools
Aguired a black and decker model 7600 router tool. Did not come with instruction manual. I cannot determine how to change the bits.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
Jun 15, 2010 | Black & Decker Tools & Hardware - Others
How do I attach multitool parts to my HT20VSK multitool? I have lost my instruction manual
To change bits you should unplug the device.
Turn the shaft while pressing on the lock button located toward the tip of the machine. Turn until lock button is allowed to depress fully.
While holding the lock button loosen the collet nut at the tip of the machine.
Remove the bit you want to replace and slide in the new one.
Sometimes you will have to tap lightly on the top of the bit to get it to release.
You may at times have to replace the chuck to accommodate the different shaft dimensions of some of the bits.
To do this you will have to remove the collet nut completely to remove the chuck.
Feb 15, 2010 | Hand Tools
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
I borrowed a black and decker rotary tool (RT 550). I can't seem to get the bit off or be able to change bits. There is no tool to use to open the bit and everywhere on-line it says ''quick swap of bit...
slide the orange on/off switch all the way back then push in the black button the switch slides over. This will lock the shaft-then use small wrench provided w/ tool to turn the collet nut
Jul 13, 2009 | Tools & Hardware - Others
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
Trouble Changing Attachment
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Oct 03, 2008 | Dremel Mini - Mite Cordless Rotary Tool
Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90 Logo
256 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
