Question about Sony Cyber-shot DSC-W120 Digital Camera
Lens area goes in and out severel time and than says turn off
I dropped my camera and the lens goes in and out like 5 times and after wards a message comes up saying to turn the power off and on again. When I do it just does the same thing again. i can still view pictures i took before it just won't let me take pictures.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 26, 2010
I have a sony cybershot camera dsc w150 and recently when turning on the camera the lens goes in and out 3-4 times and then a message comes on saying to turn off the camera,but it keeps repeating the...
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you !!
Aug 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Camera has a message coming up on screen sayng to turn camera off
Thank you!!
Jul 17, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lens goes in and out and error message 'turn
this message comes up if you have dropped your camera. try tapping the device while the message comes up. if that doesn't work then you have to take it to the sony service centre to replace the lens array. it costs about 60$ to replace it.
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Can't take new pictures!
 Delete some images then try
Still in trouble?
Come back
Oct 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Gently tap it on a table or flat surface a few times. Worked for me!
Jul 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
