Question about Garden
There seems to be a problem with the cable to the attachment clutch lever. there is no tension on it when I engage. blades wont go (may mow tiny bit). Is this someyhing I can fix. Manual does not have a good picture in it. model 917.275180
Check for a spring on your tensioner pulley there should be some holes on it for a spring to connect too and back onto the frame these sometimes come off and dont keep the belt tight maybe diagram will show this tensioner
Posted on Apr 26, 2010
When engaging the clutch lever the blades do not engage
didnt specify unit --generic answer ---check clutch lever ,,cable to tensioner ,tensioner ,pulley,,pulleys,belt
Jul 03, 2017 | Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Blades not disengaging
is the blade engagement system a lever or a switch?
If a lever , then look on the deck where the pulley applies tension to the drive belt for a sticking point. the cable from the lever will be attached to it and it should move smoothly in and out of drive position. sounds like the pulley is not retracting when cable is released. check for sticking of pulley arm or maybe a missing return to idle/off spring is broken or missing.
The deck should disengage as soon as the tension on the cable is removed.
if electric, the clutch itself is always getting power, so a swithc circuit fault is to be expected.
Jul 21, 2013 | Husqvarna 23 Hp 48" Deck Yard Tractor
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
When I finish mowing yard I disengage mower blades but they keep on turning why
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
May 14, 2010 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
