Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Water is leaking inside the freezer at the bottom. It pools and freezes. Seems to be once per day. Any ideas
  • 375 Answers
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
LEAKING FROM FREEZER, thought it was the ice maker, but seems to leak only at night. water is pooling at bottom and freezing.
You have a defrost drain that is plugged. See if you can locate the drain hose and clean it out.
May 16, 2011 | Kenmore Refrigerators
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
My samsung rs2630sh, has water pooling at the bottom of the freezer. Water will also leak out of the until onto the floor. the ice buit up so much had to break it up just to get the bottom tray out. Any...
I have the same problem. Water from the defrost coil is not running out the outlet, but freezing in the defrost "catch" pan and outlet tube. Once water freezes, then water from subsequent defrost cycles, runs into the freezer floor and eventually out to the front or side. I don't have a permanent solution, but you can take the inside panel off with the four screws and see the problem. Chip out the ice dam and clear pathway with very hot water. I have read that lowering the freezer temp may prevent. Open to new ideas or permanent solutions. Good luck!
Mar 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
75 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
