Question about Sony Walkman Sport Series NW-S205F MP3 Player
Take appart hi everyone, i like to know how things are built together. just like my walkman here down below. already took that one screw out, which is at the usb-port side. but now, i can't find a way to get the inside out. so, how long is this going to take, to find out? peace luke
  • 8,596 Answers
Sony is the one company that provides service manuals to non-servicers - call them to find out
Posted on Jul 06, 2008
Bt200 only exhausts
Here is a parts diagram. You may want to remove the four, top allen screws and pull off the head. Turn it upside down and with your thumbs push on the head valve assembly (items 9 and 10) and make sure it goes up and down freely. It is spring loaded (item 8). If it gets stuck it will blow air out the exhaust. Also a bad seal between it and the cylinder will cause the same thing.
When reinstalling the head assembly I push down from the middle of the head as evenly as possible to compress the head valve without cocking it and having it stick. I then hold the head with one hand while putting the screws back in with another. I use t handle allen wrenches. Also always lightly grease (or coat with air tool oil) any new o-rings you install. You don't want to run them dry. I use a tub of white lithium grease because I do so many. If you knew this already I apologize but it may help others that read this.
Bostitch BT200 parts diagram
Aug 11, 2012 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Changed boot sequence in bios, now I cant access bios, and screen is blank. is there an easy way to reset the laptop back to factory?
The only way to reset the BIOS is to take the laptop appart, remove the CMOS battery and short the reset jumper on the motherboard. Unfortunately this is unrealistic unless you are handy with taking things appart and putting them back together.
Let me know if you have any questions.
Jun 29, 2011 | Averatec AV1050-EB1 PC Notebook
My headphone jack no longer works i want to fix it myself ive already taken it appart .... what now ?
Dependant on how damaged it is you may just be able to solder the existing one back in place.
If you need to get a replacement, below is a link showing parts available for this model.
http://www.encompassparts.com/models/?SONMZN505
1-793-288-43 J302; HEADPHONE JACK
The above details are for the MZ-N505. If you have the MZ-N505C or MZ-505U then the above parts would not fit.
If you need any further assistance then just ask for clarification.
Please leave feedback.
Cheers
Andy
Apr 25, 2011 | Sony Net MD Walkman MZ-N505
How do I get this thing appart and put in new
First, you need to gently pry off the 'cap'on the bottom that surrounds the hole for the cord. Once removed, the side grips will simply pull away revealing 4 screws. Remove screws to take off back cover. Circuit board will then simply lift out.
You will find compatible batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Apr 18, 2010 | Braun Syncro 7526 Electric Shaver
Having trouble putting door together
Whenyou took the door apart did you take note of how so you can reverse the proceedure Sorry it is difficult to explane in words on how to put a door together all I can say is try placeing the panels from the top down and bottom up then if anything works put in all the screws halfway then after all the screws are in then tighten them as evenly as possible
Jan 22, 2009 | GE Nautilus 24" Built-in Dishwasher
How to get to the control panel
Bosh is very tricky. You will probably have to remove the outer door panel first. #15 Torx screws all around the inside of the door panel. Support the panel with your feet while you remove the bottom two screws. (Do those last!) Close the door. Then slide the door panel down about 1 in and pull away at the bottom. Notice the two plastic blocks near the bottom of the door and how they fit onto the door frame (they never stay in place!)
If the console is not loose already, remove the two #15 Torx screws on the upper sides of the door panel.
When putting it back together, put in the screws across the top of the console first, then the door panel, then the rest of the screws.
Mar 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bios Battery
You need to separate the motherboard from the back of the touchscreen.Don't try to totally disassemble it, just get it to where you can remove the board with the battery.Then you can carefully remove the small board with the battery.
Mar 09, 2008 | Aqcess Qbe Altus Tablet PC
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Sony Walkman Sport Series NW-S205F MP3 Player Logo
46 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
