Question about Mastercool (MSC90066) 5 CFM Economy Series Rotary Vane Deep Vacuum Pump 90066
Wiring issue on mastercool 5 CFM 2 stage pump
I have a Mastercool 5CFM 2 Stage pump in which the cord was pulled out of it. It was still holding on slighty but decided to just replace the cord anyway. In removing the cord I have forgot where the wires go. I see different terminals(with numbers next to them) in the back but dont know which wires plug to where. The Model # is C55JXJFY-4450. I would really appreciate the help or where I could look to solve this issue. Thanks
  • 1,889 Answers
Black wire is " hot" White wire is: neutral Green wire is ground
This is for 110v AC
Posted on Apr 25, 2010
  • cainen93
    cainen93 Apr 28, 2012
    you are a chump Jim. that isn't even what he asked and you answeer with basic information that is completely unhelpful. I have the same problem with my pump and I am VERY aware of black being hot, white being neutral and green being ground. On the pump "circuit" board there are several places you can put the "hot" lead and that was the question asked. Next time dont be a ********* and waste everyones time by just keeping your fingers off the keyboard. As for the problem the original person had, I am not sure where they go, and am having a similar problem
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
Question is whether to get an Kobalt 80 gallon 14 CFM at 90 one stage or a 60 gallon IR 18CFM at 90 if the price is the same and CFM is not the issue, but the quality of the item?
your choice of an air compressor should be based on what you are going to be using it for first of all .single stage compressors are good for about 125 psi 2 stage up to 175.which whatever one you choose do not get a oilless they wont last .you want a cast iron pump which requires oil lubrication.pumps which are made of aluminum are throw a ways
Aug 04, 2010 | Air Tools & Compressors
How do i operate it?
Go to the Mastercool web site:
http://www.mastercool.com/pages/vacuum_pumps.html
Pick out your model number and then click on "instructions" to download a manual. The most important thing is to change the oil frequently. This unit is used in HVAC to draw a vacuum on an evacuated AC system after repairs were made to insure it is free of any condensables.
Aug 01, 2010 | Mastercool 15 Cfm Deep Vacuum Pump 90059
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Sep 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need some help knowing the pump I need
Since adobe air is out of business, you will have to make one of the dial 230 volt pumps fit in its place. I cut a little notch into the media support tray to fit mine.
As far as the pump size goes, the orange 230 volt is somewhere around 11'000cfm or bigger and works just fine in my precooler.
Aug 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
May 12, 2009 | Heating & Cooling
Low voltage wires
I just tested a mastercool control box and found these 4 control wire colors:
Red (24v supply)
White (pump)
Green (low blower)
Yellow (high blower)
The yellow acted as a common for testing when the blower was not on high.
Blower on low just green has 24v.
Blower on high green and yellow have 24v.
If there was a fifth wire added hopefully it would be a ground wire.
There was also the low gauge wires that were black, white, and ground that were not control wires and delivered power to the control box.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mastercool (MSC90066) 5 CFM Economy Series Rotary Vane Deep Vacuum Pump  90066 Logo
247 people viewed this question
Top Mastercool Plumbing Experts
Donni Steen
Tom Chichester
Are you a Mastercool Plumbing Expert? Answer questions, earn points and help others
