Question about Refrigerators
I've an 8 yr old 42" Ge monogram with ice nd water dispensor unit on freezer left side. the icemaker appears to be wiorking as the green light is on and i see new ice. the external control panels for water, ice dispesning are out. so is the bulb by the side of the water,ice outlet hole. what is the probelm and fix ? paul neri 805 405 0643
    President:
  • 1,469 Answers
Hi, the question is ok, but you have to still contact the service repair company to check it out for you to be able to address the issue more better.
Take care.
Posted on May 03, 2010
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker has stopped making ice. It appears no water is getting to the ice tray. There's no sound (click) when I flip the on/off switch (but I don't know if there's supposed to be any sound). It worked...
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
