Question about Poulan Pro " Pro" Self Propelled Mower
Constant Stalling will not even try without priming and then stalls after two seconds will not stay on
  • 1 more comment
  • jesse molina Apr 25, 2010
    primed six or more times, don't know about taking mower parts apart and cleaning, gas is new.
    have tried countless times to start, same result, will start on prime but not without and not for more thank 5 seconds.
    somewhat, maybe carb problem
    where can i find repair manual for taking out and cleaning carb?
    President:
  • 2,030 Answers
One of a couple things could be wrong
1) try priming it 8 times and see what happens
2) carb is dirty and needs removed and cleaned
3) you have old stale fuel...drain it and put fresh in
Posted on Apr 25, 2010
  • Sean Wright
    Sean Wright Apr 25, 2010
    Definetly in the carb if priming works but keeps dying
Why stalling out without choke ?
Possible vacuum leak allowing more air into the motor than needed thus the need for the choke to offset the unmetered air. Check for any disconnected/collapsed/broken hoses under the hood
Jul 10, 2015 | Cars & Trucks
Why is my Jeep not wanting to stay cranked?
Your ? is very vague not even sure what stay cranked means. But assuming it won't keep running or keeps dieing or stalling. the most common cause would be poor gas pressure. As in fuel pump is failing or fuel filter is clogged or just very low on gas in tank. That's where most mechs. would start looking.
Sep 14, 2014 | Jeep 1999 Grand Cherokee Limited
Lexus SC430 Stalling Problem
Check the EVAP system canister purge valve, usually located on or near the canister itself which should be near the fuel tank. If the valve is clogged or stuck, it will cause excessive backpressure in the vapor return system, which sounds like what is happening here. Good luck, hope this helps.
Jul 15, 2013 | Cars & Trucks
1999 kia sportage stalling
You have an Electrical Issue that is probably best served to bring to a Mechanic so he can follow the Troubleshooting Matrix to get to the Bottom of the Problem
Apr 10, 2013 | 1999 Kia Sportage
I have a 2004 silerado 2500 hd 4x4 with a 6.0 engine. I hadnt driven it for a couple days and when I took it for a ride it started stalling on me. I got it home but it wont stay running. Most of the time...
When you say plugs I assume its a diesel w/glo plugs. This could only be a fuel issue; its either dirty or it has water in it or has lost it prime pressure. Dirty or watery can be fixed by draining the tank and changing the filter then flushing the line by opening the bleed screw at the primer pump and pumping it out till its clear/clean. If its the prime pressure then open the bleed screw, pump till there is no air, close the bleed screw and pump until the primer gets too hard to push. Hope this helps.
Oct 09, 2011 | Cars & Trucks
Turn key can hear fuel pump run turn key to start my truck startes for two seconds and die do it three or four times will start will dun good for a week a do it again will run good three days do it again ...
Could possibly be the anti theft system. Check out this link. When the SECURITY fails, you should see a light on the dash that says security. A symptom of a failed anti theft is starting for 1-5 seconds and then stalling repeatedly. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 15, 2011 | GMC Jimmy Cars & Trucks
Keeps stalling on me and runs really really rough
THe coolant sensor could be the culprit. It may be stuck in advanced mode or even cold mode causing it to stall at lights. The sensor may have been over tightened. These sensors need to be put in with a minimum of torque, just enough to avoid leaking. Without seeing the car this is the first place I'd look. Thanks for your question.
Sep 15, 2009 | 2001 Dodge Durango
Poulan Pro " Pro" Self Propelled Mower Logo
83 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
