Question about SkyScan 86742 Digital Atomic Wall Clock
My outdoor temp will not work
My outdoor temp. transmitter will not work
    President:
  • 2,761 Answers
If you've already cleaned the contacts and replaced the battery, your transmitter unit needs to be replaced. You can purchase a new one through the link below. If your clock's model number isn't listed, use the "Contact us" link at the top of the page.
Bill B
Posted on Apr 26, 2010
SOURCE:
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Why is outdoor temp blank?
The trick with these devices is to install batteries in the transmitter first, then wait for a time until it begins transmitting before installing batteries in the indoor unit.
Sep 17, 2015 | Measuring Tools & Sensors
Modelws 7013u how to replace and reset batteries
In systems with an outdoor transmitter and an indoor receiver, the usual battery replacement procedure is to start with the outdoor transmitter first, allow time for it to start sending data, then install the replacement batteries in the indoor unit. You should see the outdoor temperature being displayed.
Jan 03, 2015 | Measuring Tools & Sensors
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
483 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
