Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
I've an 8 yrs old GE monogram 42" side by side frig with icemaker and water/ice disesing unit on left side, freezer door. the icemaker appears to be working but the display exterior unit is not. the lights are out. when i press any of the touch buttons there's no response. the light bulb is also burned out. what is the problem and fix ? thanks Paul Neri 805 405 0643
  • neripaul Apr 26, 2010
    what is cost of fixing the problem
    President:
  • 949 Answers
It sounds like the control has a failure in the dispenser mother board. I would need the complete model number from the tag on the refrigerator. It should be on the rail near the bottom when you open the refrigerator door, if not it may be on a tag inside the unit.
Thanks!
Posted on Apr 26, 2010
  • 524 Answers
This may be a little more severe then you may think. What i am understanding from your question and statement is that the unit has to lights and no response to touch. What is happening here is that the unit control board has gone bad. Your best bet at this point is to call G&E and ask then for a replacement and/or what is it going to cost you.
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replacement of ice maker solenoid in door
Go behind the ice box and look for the water line going in. The water valve will be connected to the line. Be sure to shut off the water before attempting to do anythang.
Sep 05, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker has stopped making ice. It appears no water is getting to the ice tray. There's no sound (click) when I flip the on/off switch (but I don't know if there's supposed to be any sound). It worked...
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
122 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
