Question about Dryers
The dryer is not getting heat. What could be the problem?
  • Dryers Master
  • 43,501 Answers
If you have a gas dryerThe dryer is not getting heat. What could be the - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 26, 2010
Gas Dryer Heat wont stay on.
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Blower not getting up to speed
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irreparable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
good luck
rate these
Jan 10, 2013 | GE Profile Harmony DPGT750EC Electric...
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
Dryer stopped heating...what to do?
Hello there
Proper Voltage
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Dec 08, 2010 | Dryers
Not getting heat
If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 05, 2010 | LG DLG2532 Gas Dryer
Maytag dryer model # LDG8000AAW dryer comes on and the burner lifgts up but dryer dosen't get hot.
Hello there:
please try each step of this guide i have provided for you
Proper Voltage
Jan 19, 2010 | Dryers
The dryer does not give heat
Hello there:
Proper Voltage
8574d88.jpg Heating Element
d5b5af3.jpg Thermal Fuse
77d6bd4.jpg Thermostat
Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Feb 08, 2008 | Amana ALE643RB Electric Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
