Question about Foxconn 661MX Motherboard
Cannot Install Windows
Help! I got my PC repaired last December and my original mobo got replaced with a Foxconn 661MXPlus motherboard. The thing is I cannot boot into safe mode or my PC automatically shuts down when I boot-up sometimes or when I try to reinstall windows xp after setup loads. Also, windows hangs indefinitely when I load games or do my video editing.
I ran Memtest 86 and found no problems with my memory. Also used the onboard VGA instead of the AGP card and that didn't eliminate the problem. Removed any PCI cards and booted up, but the problem is still there. Tried installing Ubuntu but it won't boot, and I can't even reinstall Windows with a blank hard disk because my PC shutsdown after "Setup is starting Windows". Tried resetting the CMOS, but the problem went away about 30 seconds before hanging and then the same problems came back after resetting the computer.
My CPU fan reaches about 77 degrees Celsius and I never overclocked my PC.
What should I do? Will buying a better CPU heat sink solve the problem (maybe because of auto shutdown), or should I do something else with my PC?
Here are my specs:
Intel Pentium 4 3.0GHz w/ HT
1GB (2X512MB) PC3200 memory
500W Power Supply
BFG GeForce 7600 GS OC 512MB AGP
Sony DRU-700A Optical Drive
40 GB Maxtor? ATA HD (Primary) and 250 GB Maxtor ATA HD (Slave)
4 slot USB 2.0 PCI card
  • 1 more comment
  • thuganomigs Mar 24, 2008
    i forgot to mention that i already have the latest BIOS in my mobo from the Foxconn website
  • thuganomigs Mar 27, 2008
    it really worked! i replaced my heatsink w/ a scythe ninja mini. not only did my CPU's temp go down 20-30 degrees, but it became so much quieter, and some of my games run really smoothly! i'm still doing some tests to make sure everything is ok... thanks!
  • thuganomigs Apr 04, 2008
    The heatsink might've been busted cuz it's 3 years old. anyway...
    i might have resolved the hanging problem as well, but my solution got rid of annoying BSODs. When I played Worms 4, the BSOD pops-up w/in 10 mins, (or 3 hours when I just idle) but when I changed my BIOS settings, it seems to be fixed. I lowered my DRAM frequency from 200Mhz to 133Mhz, and that might've did the trick.
    you were right. the repair place i went to didn't sound like what they were doing!
    Scholar:
  • 134 Answers
Well it sure sounds like an overheating problem, and 77 degrees celcius is way too high, specialy if it's right after boot! try reseatting the heatsink and make sure the repair place put a thin coat of heatsink compound paste on the processor. You need to bring that number down so really pay extra attention to the heatsink.
The next thing would be a bad memory module check out http://www.cas411.com/ShowArticle.aspx?ID=66 , it talks about surprising behaviors of PCs when a memory goes bad.
Hope this helps!
Alex J.
Posted on Mar 24, 2008
  • Alex J.
    Alex J. Mar 27, 2008
    Glad I could help! that heatsink was not properly seated. The repair place you went to don't sound like they know what they are doing.
    Alex J.
What is the one time boot key for the Foxconn 661MXPlus mother board? to enable me the option of which operating system on which hard drive to select? Thankyou
Start your PC. Press Delete button from keyboard,it will open your BIOS setup.
Now go to boot options and select your hard drive to boot.
Hope this will help you.
Thanks for using FixYa.
May 17, 2011 | Foxconn 661FX7MF-S Motherboard
Please help!
yes, if it's an original pci and not pci-e. but unless you have already purchased the pci i would recommend that you get an agp instead, they are faster.
Sep 09, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Motherboard shorted
Unless you have about a $3000 soldering machine and lots of skills soldering, i would say just get a new mobo. the cost to fix it would be lots more than its worth
Oct 11, 2008 | Computers & Internet
Motherboard shorted ? help please
Foxconn 845GV4MR-ES Lan refuses to work
Have you installed the correct drivers for this mobo? You can get them here:
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=845GV4MR-ES&TypeID=en-us0000004
I've used these with XP Pro and everything works. You have to install the chipset driver before the others. Also, do you have the onboard network adapter enabled in the BIOS?
Jun 22, 2008 | Foxconn 845GV4MR-ES Motherboard
Intel 2.8G\400MHz problem
I would agree that 50% of the time you may get away with putting a working Hd with windows on it to run when changed to another board. When you change your motherboard, there are certain entries in the system registry that are looking for the components of the old motherboard. If the registry does not find these components, the system can become unstable.
The fact that you got windows to some what start is a good sign for the Hd. Try setting the CD as first boot device & have your windows XP in the drive. Do a format & install. I'm sure windows will install. Since you have three boards all the same you will only have to do this once. Foxconn warrants all Mb for life. You can always call at 580-272-0035
Mach Speed Technologies, Inc.
110 East 10th Street
Ada, Oklahoma 74820
Jan 08, 2008 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Mobo won't load my OS it stalls half way right before welcome scrren on xp
You Shouldn't install a Mobo like that!!.
The Motherboard will require different drivers,  to operate correctly,   Windows will be trying to load the incorrect drivers and fail as it can't find the corresponding Hardware.
you may be able to get into safe mode,  delete almost everything in the Device manager tree, reboot and let it detect everything.
still you may have problems getting in.
also there is copy protection software in Windows which should detect the major hardware change and ask you to activate again.
If this fails you may have to try a Win XP repair (not using recovery console) which should rebuild windows, detect all your hardware, whilst not loosing all your data (although you may have to re-install some of your applications (as they may become dis-associated with the Registry.)
Oct 25, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Foxconn 661MX Motherboard Logo
163 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
