Question about Char-Broil Quickset Traditional 463761006 Grill
Flames come up on front of grill ,melting knobs
Tank hose still intact
  • 140 Answers
It may need a clean
Posted on Apr 28, 2010
I have a 3 knob grand gourmet grill with a newer burner, I light the grill with the first knob, turn on the second knob, turn on the third knob and the flame goes out, any suggestions?
To troubleshoot & solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Sep 20, 2011 | Brinkmann 810-2300-B Grill
My front burner on my silver b will not ignite also their isn;t any gas coming out.I can light the 2nd &3rd burner but the heat does not get higher than 350 degrees !!!!
The problem you're having is due to a partially locked grill hose regulator.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
Aug 24, 2011 | Weber Genesis Silver B Grill
I have a 3 burner CaptnCook gas grill. The middle burner has a single flame when I try to light but does not light the whole burner row, just right at the front only. The right and left will not light at...
The problem lies with the grill's regulator and how the gas tank valve was opened.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Flame appearing from in back of front panel
This is usually a regulator problem, or a gas leak where the regulator line attaches to the back side of the knobs. Test for a gas leak first. You can use a mixture of water and liquid dish/hand soap. Saturate the area where the hose connection is, turn on the tank, but leave the knobs in the off position and do not hit the igniter. If there is a leak, you should see some bubbling where it is. If there is no leak, turn the tank off, open the valves (turn the grill knobs on) and bleed the gas out of the lines. Once it has sat for a few minutes with the knobs in the "high" position, turn them off. Then leave them off and turn on the tank, followed by one of the knobs and ignite the grill. see if the flame went away. I've seen this happen where there is not enough pressure in the line. Turning the tank off, the knobs on, bleeding the line, then closing the knobs and opening the tank and letting the gas build up pressure in the line before turning the knobs back on or trying to light the grill should resolve it.
May 11, 2010 | Char-Broil CharBroil Master Flame Gas...
Flames shoot out the front of charbroil grill melting the knob
maybe put the barbecue in different place more out of the wind
Apr 27, 2010 | Char-Broil CharBroil Master Flame Gas...
Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Mar 23, 2010 | Ducane Affinity 3100
Kemore 1 year old grill
turn tank off make sure all knobs are turned off disconnect tank from grill reconnect tank turn tank on and try again if this does not work you probably need a new regulator and hose
Aug 30, 2009 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Gasgrill
No you need to replace the valve behind the knob as well most likely this is what caused the flame.
May 31, 2008 | Kenmore Grilling
Char-Broil Quickset Traditional 463761006 Grill Logo
319 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
