Question about Panasonic Home Theater System System
Cooling fan is making noise i took it off and took it apart and didnt really know what to do so just put it back together and its still does it. what should i do?
  • Panasonic Master
  • 458 Answers
Sometimes the fans can get dirty & collect a build up of dust etc. so using something to blow into the fan & clear any dust can sometimes help. Unfortunately if this doesn't cure it then try to drop a small amount of lubricant into the motor, usually in most cases of noisy fans the only solution is to replace it.
Posted on Apr 25, 2010
I have a model 51049 Hunter Louden brushed nickel low profile ceiling fan with light; my electrician installed it, but there is a noise like a piece of metal being hit, a scraping noise, which occurs
I have the exact same fan with the exact same problem. I kept taking it apart and could not find the problem until I got it completely apart and took the big housing off. I saw the problem immediately. A couple of the wires were hanging too low and scraping on the round drum that spins. I'm glad I found it, because over time this would have worn the insulation off the wires and created a problem. A potential fire hazard even. I took one of the stiffer solid wires coming from the ceiling and used it to loop around the flimsier stranded wires that were hanging down and scraping. I rolled it all up tight as close to the ceiling as I could and put it all back to together. The fan is beautifully silent now.
I installed it myself. That's my excuse. Your electrician should know better and if he made the rookie mistake of not clearing those wires, he should take it apart and fix it himself for free.
May 06, 2014 | Hunter Dryers
I took the blades off my table fan to clean them and once i put the fan back together and turned the fan back own the blade spins and everything but no air is blowing out
I think that you may have put the blade on backwards. try taking the fan apart and reversing the blade around and reassembling the fan.
Dec 10, 2012 | Hampton Bay 24002 Ceiling Fan
Overheating
You will probably need to replace the CPU fan down the road and remove the old thermal grease between the heatsink and the processor ic for new compound, will make all the difference.
Sep 24, 2012 | Toshiba Refurbished SATELLITE CEL600 64M...
I have an HP dv9500 Intel laptop. The fan is making some pretty bad noises. I took the laptop apart according to the HP Maintenance Guide. I found tons of animal hair (I have two cats and a dog) and...
If there is nothing hitting the fan blades and the fan makes a grinding noise then the fan bearing is faulty. You may be able to place a drop of oil on the bearing under the label in the center of the fan and if this does not work then you need to replace the fan.
Apr 23, 2011 | Computers & Internet
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
Jul 20, 2009 | HP (219462-001) Cooling Fan
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Sep 11, 2007 | Windchaser PACR10 Portable Air Conditioner
Panasonic Home Theater System System Logo
108 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
