Washing machine wont stop?
I have a GE top loading washer. Everytime we run it, it goes on to the next cycle. If we have a heavy load it will go all the way through its cycle, rinse and spin, Then fills back up and runs on the next cycle sy "delicates" It never stops running unless we manually stop it. Any ideas??
    President:
  • Washing Mach... Master
  • 2,651 Answers
You have a bad timer assy, youll need to replace your timer
Posted on Mar 24, 2008
6ya staff
SOURCE:
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
GE WDSR080D washer fills and drains at same time. You have to force it to the next cycle to fix it.
how high is your stand pipe that your drainhose goes into should be ev en with cabinet top... other wise replace timer
Jan 27, 2011 | GE WDSR2080D Top Load Washer
I have a GE Front load washer model # WHDVH660HWW. Everytime it goes into spin cycle the machine vibrates/shakes and it keeps stopping and then tries to reset. Eventually shutsdown. I ahve to open door...
Sounds like one of the internal suspension/dampening units for the drum unit has broken or become unattached. Am not certain what this machine has but removal of top and rear cover should allow you to inspect the items and arrange replacement as required.
Dec 20, 2010 | GE WSXH208A Front Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
