Question about Casio AW80-7AV Wrist Watch
How do i change time and set alarm...is there a user manual
  • 2,334 Answers
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Posted on Apr 25, 2010
I cant set the arm time
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
Dec 26, 2015 | Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
I'v first time bought a digital watch fastrack 4052,n i don know how to set d timer,alarm or time settings..will u plz help me.. Thanks
look for a mode button then you can scroll to the setting you which to change. once you are there look for an adjust (or similar) button. you hold that down until something flashes or it allows you to change the desired setting. also refer to your user manual if the watch came with one
Aug 15, 2011 | Watches
PUMA FLUX watch - reset time
Press and hold the button on the upper left until it displays "HOLD" then wait 'til the light goes out, you'll see the hour-digit blinking, set the hour you want, then for the minutes, press the lower left button. Press and hold the upper left button to set the desired time.
May 02, 2010 | Puma Digital Alarm Chromograph...
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
How to change settings of Seiko world time alarm & desk clock
I have the user manual for this clock for anyone who sends me his e-mail address.....
indysandy@indy.rr.com
Feb 03, 2010 | Watches
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
Need manual/User Guide for an ''Athletic Works'' watch, model V403
Dave,
If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
Apr 26, 2009 | Watches
Can't set the alarm on a pulsar pf 3681
Pull out the time stem to the first notch. Use the bottom button or reset button to change the alarm.
Dec 22, 2008 | Pulsar 100 Meter Alarm Chronograph PF3277
Casio AW80-7AV Wrist Watch Logo
208 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
