Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU
Thermostat? When i turn my heater on it detects the pool temp as about 96 degrees when it is really 70 degrees. Therfore it will shut off to early. HELP. Thanks, Mike
  • 990 Answers
Your temp sensor has gone bad and is a small tube that goes into the water manifold. and you follow the wire back to the board. Just get a new one at your local store and slip it into place and plug the wires back in.
Posted on Apr 25, 2010
Jandy LJ Pool Heater
temp sensor might be going bad but you can go into menu and calibrate up to 4 degrees each way
Mar 24, 2014 | Jandy Laars Lite2 Lj 250,000 Btu Heater
RTH2310b thermostat not heating to temperature set, I turn it off and back on, it runs few minutes then shuts off not heating to temp set on thermostat
All thermostats have a "Differential" setting that causes the thermostat to turn off early as an energy saving feature to blow all the hot air out before the furnace fan shuts down. On some stats, there is a switch on the back for setting this and some have a programming choice for setting this time. Others have no setting but normally start the heat about 2 or 3 degrees below the set-point and shut it off 2 degrees above. In this case it would be called a 5 degree differential. Look for these as described and adjust it up 2 degrees if found. Good luck.
Nov 09, 2013 | Honeywell Programmable Thermostat Heater
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Water Temp on heater reads 126 degrees F
I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
Jun 29, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Heater shuts off 10 degrees before pool reaches the set temp.
The thermistor is probably failing and needs to be replaced. You can probably replace it yourself. We sell the part at www.arrwomotor.net
May 29, 2009 | Hayward H Series Induced Draft Abg 100,000...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU Logo
129 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
