Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Dryer turns on but seems to be jammed - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
A dryerdryer turns on but seems to be jammed - 2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 26, 2010
My maytag dryer mde308dayw will not turn maybe belts broken help me out please
Use a putty knife to release the top then get the front panel off then remove the shroud and the drum. My home video of a dryer like yours:
Oct 07, 2012 | Maytag Dryers
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
Ge dryer - buzzes when the start button is pushed but the dryer motor doesn't start or the dryer drum moves. could be a jam or the motor? Motor didn't seem to be a problem before today.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2011 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Beko drvs73w dryer keeps breaking belts. Drum seems to jam at door end and motor contines to melt the belt.The bearings are good . The dryer is only 18 months old. Every time belt breaks when I investigate...
check your drum rollers/glides and your idler arm(it is suggested to change this with the belt), here is a website hope it helps,Tim:
http://www.partselect.com/dryer+inspect-pulley+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 27, 2011 | Dryers
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Dec 14, 2010 | Amana ALG443RAW Gas Dryer
Dryer motor just hums, doesn't spin, kenmore front loading dryer
Try turning the drum by hand with the unit turned off. If it seems fairly easy to turn, then check the motor to see if it has a capacitor (about 2 to 3 inches long and 1 inch in diameter with two connections).This capacitor is used by the motor for starting. Replace the capacitor. If the drum is very hard to turn, something may be jamming the drum or the motor bearings may be frozen (new motor). Hope this helps.
Sep 26, 2009 | Dryers
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
