Question about Nesco Gardenmaster Digital Food Dehydrator
I need to rewire the hydrator and need diagram to complete the wi
I need to rewire the hydrator and need diagram to follow
1st -If you don't see how you can hook up 5 wires with 3 caps - you're forgetting the household cord wire.
How to wire it correctly:
This is how mine is wired (same brand perhaps a different mode)l:
1. Connect one side of the household current (big white wire) to the part going into the knob for the temperature control (the rheostat )
Put on one of the twisty plastic caps.
- Now variable current is going into the heating elements.
2. Find the two wires coming out of the heater part.
One carries the juice, the other goes back to complete the circuit.
(Red & black are always IN current - white & blue are always return wires to complete circuits coming OUT of a device)
3. Connect the black motor wire to the red (juice carrying) wire from the heater. (put on a twisty cap) Now you have variable current going INTO the fan.
4. Connect up the rest to the other part of the big white plug to complete all the circuits. (should all be white or blue) Put on a twisty!
You're done. When testing be sure to not let the elements touch the plastic they can melt and stick to it very quickly.
How to bypass the switch if the motor isn't working:
I would NOT recommend doing this for the heater element. You might cause fire.
note: I had to bypass the rheostat for the fan because it was putting out enough current for the motor and the heater.
In that case I only need two twisty caps.
Just hook the motor up directly with the juice going before the rheostat and then the rest of the outgoing circuits to the other return wire of the household electric cord.
Now I vary the temperature but fan will run at a constant rate.
Posted on Oct 21, 2012
I have a gm- pontiac 2004 grand prix and the wiring to my headlights is all messed up. Needs to be completely rewired. I need headlight wiring diagram for this. Where can I find the wiring diagram?
if it is that bad , go to a wreckers / junk yard and get the full wiring harness and replace the existing harness
wiring diagrams are in the workshop manual available from ant auto parts shop
Oct 19, 2016 | Pontiac Cars & Trucks
I need full complete wiring diagram for my 2001 Pontiac grand am gt Had a monsoon stock
Check the fuse first. Next replace the amp. It can be rewired at the amp. You need a volt /ohm meter to do it.
Feb 27, 2016 | Pontiac Cars & Trucks
I am trying to rewire complete unit a gs110x,should I.buy a complete harness r make my own need a diagram today.t o help me!
a complete harness will have the correct colored wires and connectors and the job will be virtually trouble free
would one you make be that good
Oct 18, 2015 | Cars & Trucks
I HAVE A 2007 KAWASAKI 610 MULE, I NEED THE COLOR CODE TO REWIRE THE IGNITION SWITCH
go to your local dealer . tell them what you need , they will photo copy it from their repair manual.,prolly complete diagram too. kaw. very good about this kind of help.
Jul 14, 2014 | ATVs
How to wire back lighting
I am sorry but we have no wiring diagrams here due to the diagrams being copy protected. Sorry again.
Oct 18, 2012 | Cars & Trucks
REWIRE
Series wiring of a 4 ohm DVC subwoofer will result in an 8 ohm load.
See the following diagram.
The diagram listed has a dual 2 ohm voicecoil, netting 4 ohm, however in your case, the dual 4 ohm sub will net an 8 ohm load.
Dec 26, 2008 | Jl Audio 12W6v2 Car Subwoofer
Need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Dec 18, 2008 | 1987 Jeep Wrangler
Vw ignition coil wiring problem on a 1977 scirocco
I have completely rewired my Volkswagen dune buggy with a new wiring harness. I have followed the wiring diagram to the tee. It won't start! The wiring diagrams I have on the ignition system are not really clear either. I am sure there is just a wire left out somewhere. Where Can I get an in depth wiring diagram for a 1600cc '73 beetle engine? Thanks in advance...............Claud
Aug 15, 2008 | Volkswagen Scirocco Cars & Trucks
Nesco Gardenmaster Digital Food Dehydrator Logo
326 people viewed this question
Top Nesco Kitchen Appliances - Others Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Nesco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
