Question about Car Audio & Video
Mitsubishi spacewagon I have stripped my spacewagon to get to the heater matrix now I need to put it back together The matrix is in place but the rest of the parts ????? any diagrams or pictures or step by step guide any ideas Thanks James
How do i loosen alternator
Posted on Jun 21, 2011
Thanks
Been searching all day 4 the manual any ideas
Posted on Mar 25, 2008
  • 149 Answers
Please tell me you havent taken it apart without a clue as to how to put it together again......
All you can do now is to get a haynes manual for your model. You can then use this as a reference whilst in the car.
Posted on Mar 23, 2008
Change license plate lamp bulb 2004 Mitsubishi endeavor
there SHOULD BE AT LEAST TWO SCREWS HOLDING THE LICENCE PLATE LENS IN PLACE .REMOVE THE SCREWS AND PULLTHE BULBS OUT,THEN PUT (NEW BULBS)IN PUT IT BACK TOGETHER,MAKE SURE THE NEW BULBS WORK BEFORE PUTTING IT BACK TOGETHER
Feb 26, 2014 | 2004 Mitsubishi Endeavor
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
I need a complete users manual for mitsubushi spacewagon Glxi 1996 model. 1. Right now I have this problem the SRS light is on continualy on the dashboard.
the dreaded spacewagon ,have a customer with one of these and she can talk the hind legs off of a donkey ,anyway try the check under the front seats for the wiring connector to the pyrotechnics and clean all the connections with a soft lead pencil ,i think this may well work on this model
Feb 15, 2011 | Mitsubishi Passenger Cars & Trucks
My 2003 mitsubishi lancer es's heat control knob has snapped off.!!! I used plyers to turn it over last winter and now it seems stripped and wint go back to heat.. Is there a way i can just flip a...
Hello jeffgranstro
Sorry to say there's no easy button in the automotive world yet. You're heater controls are cable
operated and a cable problem most likely caused the knob problem. If you just want a temporary
fix, remove the control assy. from the dash. The front trim cover is held by 8 clips 2 top 2 bottom
and 2 on each side, with a small thin screwdriver, gently pry around the cover till it pops off.
At this point you should be able to see if there are screws or clips that hold the assy. in place.
The objective is to remove the problem cable from the assy. and pull it down from under the dash
where you can operate it with a pair of baby vise grips. Next, put the rest of the heater control assy. and trim plate back in place, and use those controls normaly. Thats one way to get by what is a stupid design to start with. Hope this helps.
Dec 16, 2010 | 2003 Mitsubishi Lancer
2nd and 4th gear gone in my mit spacewagon also reverse
yes but it will cost a lot more than changing and it usually is not a sucess.
Aug 04, 2009 | 1994 Mitsubishi Galant
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Mitsubishi Manul
i'm sorry to tell you but no on makes a repair manual for your vehicle
tom
Dec 20, 2008 | 1987 Mitsubishi Passenger
Fan belt broke on mitsibusi spacewagon.2.4
look under the hood, there should be a diagram somewhere in engine compartment.
Dec 15, 2008 | 1998 Mitsubishi Galant
02 galant heater not working
As me and my stepdad just discovered, the Galant came with an added feature to help the AC use less energy, by placing a heater valve within the dashboard. After pulling about 10-12 screws and half the dashboard apart, we simply opened the valve permanently. Many cars out there work that way all the time. Now after changing those lousy clamps into actual hose clamps by the firewall, my wife enjoys cool air in the summer and heat the whole winter. Hope this helps, there is a site that will actually show you a video of putting dash back together, as author did not film the disassembly.
Sep 10, 2008 | 2002 Mitsubishi Galant
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
