Question about Roxio Easy Media Creator 10 Suite
Roxio photosuite c++runtime error
Cannot open photo files in photosuite. Have reinstalled with temporary success. It ran ok for a while and now again have problem.
  • taran_2005
    taran_2005 May 11, 2010
    Hi, Did the Clean install Resolve your Query? Kindly tell me the update . Thanks!!
roxioking
  • 19 Answers
SOURCE: Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
Posted on Apr 01, 2009
SOURCE: Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
karoon.yip@gmail.com
Posted on Feb 11, 2010
DHINCE10
  • 169 Answers
SOURCE: i can't run roxio creator 10 on my computer. i am
You can try perform the steps below:
  1. Click Start --> Run.
  2. Type "msconfig" and click on the OK button.
  3. Select the Startup tab.
  4. Disable (uncheck) RoxWatchTray and/or CommonSDK (if present)
  5. Go to the Services tab.
  6. Disable Roxio Hard Drive Watcher.
  7. Click on the Apply button and then click on OK.
  8. Click YES to restart the computer.
  9. Run the program again
Posted on Mar 07, 2011
DHINCE10
  • 169 Answers
SOURCE: I'm trying to start Roxio
Please refer to the link below as it will help you resolving this issue, Make sure to follow the steps carefully.
http://kb.roxio.com/search.aspx?URL=/content/000244CR&PARAMS=set-locale=en
Cheers . . .
DHINCE10
  • 169 Answers
SOURCE: i keep getting this message up all the
You might want to try to link below it has a troubleshooting steps needed to fix this issue.
http://kb.roxio.com/search.aspx?URL=/content/000181CR&PARAMS=set-locale=en
Cheers . . .
Posted on Mar 16, 2011
Tip
Microsoft Visual C++ Runtime Library error when starting Roxio creator
Hi.
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
Regards.
on Feb 26, 2010 | Computers & Internet
Acer crystal eye webcam runtime error problem
Try reinstalling your camera driver and application program.
Mar 28, 2012 | Computers & Internet
Two computers ago, and two operating systems ago I purchased MGI Photosuite 4 software. I have been using it for about 10 years. I have hundreds of collages saved that require the MGI software to read and...
Wndows installers have changed over the years, so it's not a surprise that the program couldn't be reinstalled. The Roxio Photosuite 8 is listed as a Win2000-XP product; so it may not be the correct release for Win7 either unless you use a workaround. Look here for the current Roxio slide show products: http://www.roxio.com/enu/store/photo.html?rTrack=m_pro_photo
Workarounds: go with a dual-boot or virtual computer system. Win7 Pro and Ultimate let you run a virtual XP computer for free (download two programs - the virtual PC software and then XP mode). All other choices will require a licensed version of XP installed either in the virtual computer program or in a second partition for dual-boot. I've found that files can not be transferred directly from XP mode to the real computer; they must be stored on external media. Then install your software as you would on any stand-alone computer.
I hope this helps.
Aug 21, 2010 | Computers & Internet
Cannot find file
do one thing open that window where all the pictures are stored.......
and open the photosuite 3 then drag the photos from there in the photosuite 3
Jul 25, 2009 | MGI Software PhotoSuite 3 for PC
Files not found
type the name of the file if not then use data recovery programme
Jun 17, 2009 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Running MGI Photosuite version 8.05 in Vista
MGI Photosuite on Vista, THE FINAL SOLUTION!!! First you need to get hold of an MGI disc or a download. I have been trying to get MGI Photosuite III SE to install on Vista for months without success and then when I thought I'd finally sorted it I could not launch the program due to a script error. You do not need Virtual PC, Virtual XP or any add-ons. Simply find and right click the the MGI setup file, check the run in compatibility mode as Windows XP SP2 and install. After install, send a program launch shortcut to your desktop, right click, go to properties and check the Windows XP compatibility mode once again. Finally, while you still have the compatibility screen open add a tick check to Run As Administrator. Hey presto my beloved MGI Photosuite is back! MGI is fantastic for being user friendly and simple, and although I know other users insist there are better programs, I’ve tried loads and I still think it’s a winner.
Mar 25, 2009 | Computers & Internet
Roxio creator 2009 runtime error
Install the software again and then try. if you did not get successed plz maintain the error time which time this error accure. at the first run this program. and the between when you create a cd or dvd.
ok
bye
Nov 13, 2008 | Computers & Internet
Incompatible Driver(s)
I would uninstall Photosuite.
I don't think that Roxio is supporting that program anymore. I have version 7.0 and it does some goofy things in Windows XP they never fixed in the slide show mode.
Jun 10, 2008 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Roxio Easy Media Creator 10 Suite Logo
393 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
