Question about Troy-Bilt Pony Garden Tiller
Troy-bilt tiller The tires will not move freely when I attempt to move the tiller. The tiller will rotate the tires when engaged and move forward. Also, I am able to reverse the tiller and the tires will rotate to move the tiller backwards. When the tiller is shut off the tires will not move.
  • 93 Answers
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Posted on Mar 07, 2015
  • 376 Answers
SOURCE: troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
Posted on May 25, 2009
#1 Taper
  • 1041 Answers
SOURCE: Tiller starts easily but cuts out when engaging tines - 3.75 HP
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. If the carb. has a foat, then you can use the Den tek Brush on the jet as well. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 14, 2009
bbreton
  • 437 Answers
SOURCE: need flywheel K161T tiller 7 hp kohler
Go to www.precisionope.com. Find Kohler under OEM parts.
Good Day.
Posted on Oct 07, 2009
  • 221 Answers
SOURCE: troy bilt pony tiller will only work in reverse
These kinds of problems almost always require opening and inspecting the gearbox. Hopefully if you can do this is will be something simple you can repair. Good luck.
Posted on Jul 01, 2010
jyackle5
  • 8197 Answers
SOURCE: looking for manuel for pony
You can get the manual on the link below.
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/tillers/769-03556.pdf
Posted on Feb 20, 2011
On my 40 year old Troy Bilt Horse I cannot lift the clutch handle back up once I have it engaged to go forward, I need to push the roller assembly forward with my toe to allow the handle to release back to...
Sounds like your belt adjusting block is too high. When engaged the center line of the roller should be just forward of the corner of the block. If the block is to high the roller moves to far forward and becomes very hard to release. There should be about 3/8 inch between the front of the roller and the face of the mounting bracket.
Jul 09, 2014 | Troy-Bilt Garden
I have a 1988 troy bilt horse 8hp the tines rotate when its engaged or in disengaged
check the shift linkage sometimes the pins fall out when you shift it does it move to freely
Apr 19, 2012 | Garden
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Pony s/n P92695 5Hp Briggs. Drive wheels won't stay engaged. Lever jumps out. Can hold lever in with not much effort and will stay engaged. Any adjustments?
yes there is an adjustment. follow your shift lever down and you will find a block of iron with 2 bolts holding it. you will also see ond the lever itself a spring loaded pin.most of the time this pin gets gummed up and does not engage the block completely.clean and ensure the pin moves freely. if this does not solve the prob then the block can be moved up or down by loosening the bolts.
Sep 06, 2009 | Troy-Bilt Pony Garden Tiller
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt Pony Garden Tiller Logo
185 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
