Question about Admiral AW22 Top Load Washer
Sp;in cycle works but it will not fill with water on any setting. There is water to the unit.
  • 77 Answers
If water will not go into the machine and you have water going to the unit it is probably the water inlet valve that needs to be replaced
Posted on Apr 25, 2010
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Aug 02, 2009 | Dishwashers
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
No water going inside, but water to dishwasher fine
If it is supposed to be the filling cycle and you have no voltage to the water fill soleniod then a timer contact is not making connection or there is no voltage to the timer relay. Fix it!
May 07, 2009 | Dishwashers
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
Water-heating cycle
Timer
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
U-LINE BCM95 NOT CYCLING
These units take a full cycle to get to the fill cycle, so you won't get ice on the first cyle unless you manually fill the tray when you first power it on. You may have some air in the water line and need to cycle a few times to fully bleed the air out. Also check the water inlet for debris in the filter screen using a small brass brush, then bleed out air -with water on- while tightening back hose connection avoiding need to bleed while cycling. Lyle
Nov 11, 2008 | U-Line Icemaker
Admiral AW22 Top Load Washer Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
